Can no longer pair Matter over WiFi devices
I have over 60 Matter devices that I’ve successfully paired in the past via Hubitat, SmartThings, and HA.
All was great until recently. Now suddenly I can no longer pair any Matter devices on any of my hubs. It fails with both Android and iPhone pairing attempts.
I put my phone on the IoT wireless network, I initiate pairing on the device, scan the QR code, and then it times out looking for the device.
It doesn’t make any difference what the hub is, or the phone type.
The only thing I’ve recently added to my network is a SLZB-MR4U that I configured with HA, but I don’t have any devices to pair with it, so haven’t tested it yet, but I’m not sure how that could affect, say pairing with Hubitat for example.
So this isn’t my first rodeo, I’ve successfully paired dozens of devices in the past.
I have even tried re-sharing existing paired devices between Hubitat and HA, using share codes, and those all fail as well.
I don’t see anyting in the HA Matter logs that’s helpful.
I have Googled everything I can come up with on Matter pairing failures and nothing has helped.
So what has gone so catagorically wrong that I can’t pair any device, using Android or IOS, to any hub type that I have?
I am running HA OS on a Proxmox VM.
Welcome to the Home Assistant command line interface.
Home Assistant Supervisor is running!
System information:
IPv4 addresses for enp6s18: 192.168.1.13/22
IPv6 addresses for enp6s18: fd18:f03e:a9b4:5d5c:f049:b165:d37a:c5c/64, fe80::604a:b50:c39e:b123/64
OS Version: Home Assistant OS 17.1
Home Assistant Core: 2026.2.2
Home Assistant URL: http://homeassistant.local:8123
Observer URL: http://homeassistant.local:4357
System is ready! Use browser or app to configure.
➜ ~ ip addr
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host noprefixroute
2: enp6s18: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP qlen 1000
link/ether 02:05:3c:d8:5c:51 brd ff:ff:ff:ff:ff:ff
inet 192.168.1.13/22 brd 192.168.3.255 scope global dynamic noprefixroute enp6s18
valid_lft 3358sec preferred_lft 3358sec
inet6 fd18:f03e:a9b4:5d5c:f049:b165:d37a:c5c/64 scope global dynamic noprefixroute
valid_lft 1774sec preferred_lft 1774sec
inet6 fe80::604a:b50:c39e:b123/64 scope link noprefixroute
3: hassio: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP
link/ether ca:65:45:42:16:91 brd ff:ff:ff:ff:ff:ff
inet 172.30.32.1/23 brd 172.30.33.255 scope global hassio
inet6 fd0c:ac1e:2100::1/48 scope global flags 02
inet6 fe80::c865:45ff:fe42:1691/64 scope link
4: docker0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP
link/ether 26:df:33:57:77:84 brd ff:ff:ff:ff:ff:ff
inet 172.30.232.1/23 brd 172.30.233.255 scope global docker0
inet6 fe80::24df:33ff:fe57:7784/64 scope link
5: vethed0a123@enp6s18: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master hassio state UP
link/ether b2:e7:47:d5:83:f5 brd ff:ff:ff:ff:ff:ff
inet6 fe80::b0e7:47ff:fed5:83f5/64 scope link
6: veth51a24d8@enp6s18: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master docker0 state UP
link/ether 7e:e0:e6:46:5b:07 brd ff:ff:ff:ff:ff:ff
inet6 fe80::7ce0:e6ff:fe46:5b07/64 scope link
7: vethde9d117@hassio: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master hassio state UP
link/ether 3e:73:a8:d8:49:b8 brd ff:ff:ff:ff:ff:ff
inet6 fe80::3c73:a8ff:fed8:49b8/64 scope link
8: vethf7a836e@enp6s18: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master hassio state UP
link/ether 6e:3e:24:64:76:73 brd ff:ff:ff:ff:ff:ff
inet6 fe80::6c3e:24ff:fe64:7673/64 scope link
9: veth118d951@enp6s18: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master hassio state UP
link/ether 4a:14:18:2f:96:af brd ff:ff:ff:ff:ff:ff
inet6 fe80::4814:18ff:fe2f:96af/64 scope link
10: vethccaa886@enp6s18: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master hassio state UP
link/ether 0e:37:d6:ee:55:16 brd ff:ff:ff:ff:ff:ff
inet6 fe80::c37:d6ff:feee:5516/64 scope link
I didn’t see it mentioned, but is HA also on the IOT network?
Yes. All devices and hubs are on the same vlan.
Would be difficult to say. I’ll stick with Matter over WiFi for now. The phone gives the Matter over WiFi device the WiFi credentials of the WiFi the phone is currently on (passes the credentials using bluetooth), the device joins the WiFi, gets/formulates an IPv6 address and starts sending out _matterc._udp packets (using IPv6). The phone starts listening for _matterc._udp from the device. Once it does this, then it commissions the device to itself and then shares it with HA Matter which in turn starts listening for _matterc._udp.
What I would recommend would be to install an App on the phone that can monitor for mDNS advertisements and see if it actually receives these _matterc._udp advertisements
