I am running HASSIO 0.113.0 and would like to upgrade to 0.114.3 but after four tries i think I give up, it can not be done.
Host software is newest HassOS 4.12
But when i click update, it starts and Hassio never returns, it becomes frozen, nothing black screens, nothing, no SSH no GUI, nothing.
Only thing I can do is a reboot hardware like shorting run on my raspi 3, after that it is there again with the old 0.113.0.
I have no clue, but seems here it stops the updates, for I need the simple click a button solution the rest is abracadabra, do lack the knowledge to tinker in scripts, SSH all those things, never got SSH working, gives an error too, but I do not need it as long as buttons to upgrade do what they should do
Well anyone smart enough to get my nose pointing in the right direction, please
Nothing out of the ordinary, no errors nothing. Everything runs fine still it is impossible to update.
No wait one error I did indent it:
20-08-26 15:38:28 INFO (MainThread) [supervisor.plugins.dns] Start CoreDNS plugin
20-08-26 15:38:28 INFO (MainThread) [supervisor.misc.forwarder] Start DNS port forwarding to 172.30.32.3
20-08-26 15:38:28 INFO (SyncWorker_0) [supervisor.docker.interface] Clean hassio_dns application
20-08-26 15:38:33 INFO (SyncWorker_0) [supervisor.docker.dns] Start DNS homeassistant/armv7-hassio-dns with version 9 - 172.30.32.3
20-08-26 15:38:33 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
20-08-26 15:38:33 INFO (SyncWorker_0) [supervisor.docker.interface] Attach to homeassistant/armv7-hassio-audio with version 17
20-08-26 15:38:33 INFO (MainThread) [supervisor.plugins.audio] Start Audio plugin
20-08-26 15:38:33 INFO (SyncWorker_0) [supervisor.docker.interface] Clean hassio_audio application
20-08-26 15:38:36 INFO (SyncWorker_0) [supervisor.docker.audio] Start Audio homeassistant/armv7-hassio-audio with version 17 - 172.30.32.4
20-08-26 15:38:36 INFO (SyncWorker_0) [supervisor.docker.interface] Attach to homeassistant/armv7-hassio-cli with version 25
20-08-26 15:38:36 INFO (MainThread) [supervisor.plugins.cli] Start cli plugin
20-08-26 15:38:36 INFO (SyncWorker_0) [supervisor.docker.interface] Clean hassio_cli application
20-08-26 15:38:41 INFO (SyncWorker_0) [supervisor.docker.cli] Start CLI homeassistant/armv7-hassio-cli with version 25 - 172.30.32.5
20-08-26 15:38:41 INFO (SyncWorker_0) [supervisor.docker.interface] Attach to homeassistant/armv7-hassio-multicast with version 3
20-08-26 15:38:41 INFO (MainThread) [supervisor.plugins.multicast] Start Multicast plugin
20-08-26 15:38:41 INFO (SyncWorker_0) [supervisor.docker.interface] Clean hassio_multicast application
20-08-26 15:38:43 INFO (SyncWorker_0) [supervisor.docker.multicast] Start Multicast homeassistant/armv7-hassio-multicast with version 3 - Host
20-08-26 15:38:43 INFO (MainThread) [supervisor.updater] Fetch update data from https://version.home-assistant.io/stable.json
20-08-26 15:38:44 INFO (SyncWorker_0) [supervisor.docker.interface] Attach to homeassistant/raspberrypi3-homeassistant with version 0.113.0
20-08-26 15:38:44 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /
20-08-26 15:38:44 INFO (MainThread) [supervisor.hassos] Detect HassOS 4.12 / BootSlot B
20-08-26 15:38:45 INFO (MainThread) [supervisor.store.git] Load add-on /data/addons/core repository
20-08-26 15:38:45 INFO (MainThread) [supervisor.store.git] Load add-on /data/addons/git/15ef4d2f repository
20-08-26 15:38:45 INFO (MainThread) [supervisor.store.git] Load add-on /data/addons/git/a0d7b954 repository
20-08-26 15:38:46 INFO (MainThread) [supervisor.store] Load add-ons from store: 69 all - 69 new - 0 remove
20-08-26 15:38:46 INFO (MainThread) [supervisor.addons] Found 6 installed add-ons
20-08-26 15:38:46 INFO (SyncWorker_0) [supervisor.docker.interface] Attach to hassioaddons/ssh-armv7 with version 7.5.0
20-08-26 15:38:46 INFO (SyncWorker_1) [supervisor.docker.interface] Attach to homeassistant/armv7-addon-mosquitto with version 5.1
20-08-26 15:38:46 INFO (SyncWorker_2) [supervisor.docker.interface] Attach to esphome/esphome-hassio-armv7 with version 1.14.5
20-08-26 15:38:46 INFO (SyncWorker_3) [supervisor.docker.interface] Attach to homeassistant/armv7-addon-samba with version 9.2.0
20-08-26 15:38:46 INFO (SyncWorker_5) [supervisor.docker.interface] Attach to 15ef4d2f/armv7-addon-esphome-dev with version dev
20-08-26 15:38:46 INFO (SyncWorker_4) [supervisor.docker.interface] Attach to homeassistant/armv7-addon-check_config with version 3.4.0
20-08-26 15:38:46 INFO (MainThread) [supervisor.snapshots] Found 2 snapshot files
20-08-26 15:38:46 INFO (MainThread) [supervisor.discovery] Load 1 messages
20-08-26 15:38:46 INFO (MainThread) [supervisor.ingress] Load 1 ingress session
20-08-26 15:38:46 INFO (MainThread) [supervisor.misc.secrets] Load Home Assistant secrets: 1
20-08-26 15:38:46 INFO (MainThread) [main] Run Supervisor
20-08-26 15:38:46 INFO (MainThread) [supervisor.api] Start API on 172.30.32.2
20-08-26 15:38:46 INFO (MainThread) [supervisor.utils.gdbus] Call de.pengutronix.rauc.Installer.Mark on /
20-08-26 15:38:46 INFO (MainThread) [supervisor.hassos] Rauc: B - marked slot kernel.1 as good
20-08-26 15:38:47 INFO (MainThread) [supervisor.addons] Phase ‘AddonStartup.INITIALIZE’ start 0 add-ons
20-08-26 15:38:47 INFO (MainThread) [supervisor.addons] Phase ‘AddonStartup.SYSTEM’ start 1 add-ons
20-08-26 15:38:47 INFO (SyncWorker_4) [supervisor.docker.interface] Clean addon_core_mosquitto application
20-08-26 15:38:49 INFO (SyncWorker_4) [supervisor.docker.addon] Start Docker add-on homeassistant/armv7-addon-mosquitto with version 5.1
20-08-26 15:38:52 INFO (MainThread) [supervisor.services.modules.mqtt] Set core_mosquitto as service provider for mqtt
20-08-26 15:38:54 INFO (MainThread) [supervisor.addons] Phase ‘AddonStartup.SERVICES’ start 2 add-ons
20-08-26 15:38:54 INFO (SyncWorker_0) [supervisor.docker.interface] Clean addon_core_samba application
20-08-26 15:39:01 INFO (SyncWorker_0) [supervisor.docker.addon] Start Docker add-on homeassistant/armv7-addon-samba with version 9.2.0
20-08-26 15:39:01 INFO (SyncWorker_1) [supervisor.docker.interface] Clean addon_a0d7b954_ssh application
20-08-26 15:39:04 INFO (SyncWorker_1) [supervisor.docker.addon] Start Docker add-on hassioaddons/ssh-armv7 with version 7.5.0
20-08-26 15:39:10 INFO (SyncWorker_5) [supervisor.docker.interface] Start homeassistant
20-08-26 15:39:11 INFO (MainThread) [supervisor.homeassistant] Wait until Home Assistant is ready
20-08-26 15:39:48 INFO (MainThread) [supervisor.homeassistant] Updated Home Assistant API token
20-08-26 15:40:04 INFO (MainThread) [supervisor.homeassistant] Detect a running Home Assistant instance
20-08-26 15:40:04 INFO (MainThread) [supervisor.addons] Phase ‘AddonStartup.APPLICATION’ start 2 add-ons
20-08-26 15:40:04 INFO (SyncWorker_5) [supervisor.docker.interface] Clean addon_15ef4d2f_esphome application
20-08-26 15:40:06 INFO (SyncWorker_5) [supervisor.docker.addon] Start Docker add-on esphome/esphome-hassio-armv7 with version 1.14.5
20-08-26 15:40:06 INFO (SyncWorker_2) [supervisor.docker.interface] Clean addon_15ef4d2f_esphome-dev application
20-08-26 15:40:14 INFO (SyncWorker_2) [supervisor.docker.addon] Start Docker add-on 15ef4d2f/armv7-addon-esphome-dev with version dev
20-08-26 15:40:19 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
20-08-26 15:40:19 INFO (MainThread) [supervisor.misc.hwmon] Started Supervisor hardware monitor
20-08-26 15:40:19 INFO (MainThread) [supervisor.core] Supervisor is up and running
20-08-26 15:40:19 INFO (MainThread) [supervisor.host.info] Update local host information
20-08-26 15:40:19 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
20-08-26 15:40:19 INFO (MainThread) [supervisor.updater] Fetch update data from https://version.home-assistant.io/stable.json
20-08-26 15:40:19 INFO (MainThread) [supervisor.host.services] Update service information
20-08-26 15:40:19 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
20-08-26 15:40:20 INFO (MainThread) [supervisor.host.network] Update local network DNS information
20-08-26 15:40:20 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/NetworkManager/DnsManager
20-08-26 15:40:20 INFO (MainThread) [supervisor.host.sound] Update PulseAudio information
20-08-26 15:47:34 INFO (SyncWorker_5) [supervisor.docker.addon] Start Docker add-on homeassistant/armv7-addon-check_config with version 3.4.0
20-08-26 15:49:27 INFO (SyncWorker_4) [supervisor.docker.interface] Clean addon_a0d7b954_ssh application
20-08-26 15:50:05 INFO (SyncWorker_4) [supervisor.docker.addon] Start Docker add-on hassioaddons/ssh-armv7 with version 7.5.0
20-08-26 15:52:51 INFO (SyncWorker_3) [supervisor.docker.interface] Clean addon_a0d7b954_ssh application
20-08-26 15:53:26 INFO (SyncWorker_3) [supervisor.docker.addon] Start Docker add-on hassioaddons/ssh-armv7 with version 7.5.0 20-08-26 15:53:30 ERROR (MainThread) [supervisor.api.ingress] Ingress error: Cannot connect to host 172.30.32.1:62094 ssl:default [Connection refused]
20-08-26 17:40:19 INFO (MainThread) [supervisor.updater] Fetch update data from https://version.home-assistant.io/stable.json
20-08-26 17:46:59 INFO (MainThread) [supervisor.host.info] Update local host information
20-08-26 17:46:59 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
20-08-26 17:47:00 INFO (MainThread) [supervisor.host.services] Update service information
20-08-26 17:47:00 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
20-08-26 17:47:00 INFO (MainThread) [supervisor.host.network] Update local network DNS information
20-08-26 17:47:00 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/NetworkManager/DnsManager
20-08-26 17:47:00 INFO (MainThread) [supervisor.host.sound] Update PulseAudio information
20-08-26 18:40:19 INFO (MainThread) [supervisor.store.git] Update add-on GitHub - esphome/home-assistant-addon: ESPHome Home Assistant Add-on repository
20-08-26 18:40:19 INFO (MainThread) [supervisor.store.git] Update add-on GitHub - home-assistant/addons: ➕ Docker add-ons for Home Assistant repository
20-08-26 18:40:19 INFO (MainThread) [supervisor.store.git] Update add-on GitHub - hassio-addons/repository: Home Assistant Community Add-ons repository
20-08-26 18:40:22 INFO (MainThread) [supervisor.store] Load add-ons from store: 69 all - 0 new - 0 remove
20-08-26 19:40:19 INFO (MainThread) [supervisor.updater] Fetch update data from https://version.home-assistant.io/stable.json
20-08-26 19:53:39 INFO (MainThread) [supervisor.host.info] Update local host information
20-08-26 19:53:39 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
20-08-26 19:53:39 INFO (MainThread) [supervisor.host.services] Update service information
20-08-26 19:53:39 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
20-08-26 19:53:40 INFO (MainThread) [supervisor.host.network] Update local network DNS information
20-08-26 19:53:40 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/NetworkManager/DnsManager
20-08-26 19:53:40 INFO (MainThread) [supervisor.host.sound] Update PulseAudio information
As suggested but that gave another error, which had to do with a hidden password, of which i have no knowledge and i think for safety, I understand, all is already way to hard to reach like host ip tables SSH not running either, I started with version 0.17 i think back then I know all was open to the world but it was so much easier to change things, now I need keys, passwords logins, generated Tokens.
It is finally getting to complicated for me, and as i read with an other user I can better revert to an old house without automation
