I’m currently trying to install some grafana plugins in the GitHub - hassio-addons/addon-grafana: Grafana - Home Assistant Community Add-ons but I can’t get it working:
[cont-init.d] grafana.sh: executing...
Error: ✗ Get "https://grafana.com/api/plugins/repo/grafana-clock-panel": dial tcp [2600:1901:0:b3ea::]:443: connect: cannot assign requested address
[14:59:47] FATAL: Failed installing Grafana plugin: grafana-clock-panel
[cont-init.d] grafana.sh: exited 1.
My configuration looks like this:
certfile: fullchain.pem
env_vars: []
keyfile: privkey.pem
plugins:
- grafana-clock-panel
ssl: true
which is the basic config + the plugin line.
When I try to reach grafana.com
via curl it also fails with this:
curl (7): Couldn't connect to server
When I start the terminal plugin, it tells my some ipv6 adresses, so there is something there. If i run ip a
or ifconfig
, there is just the 172* ipv4 address.
Do you have any idea why I can’t access grafana.com
