It is my first topic, so I would like to say hello to everyone!
I have a problem with my HA, like the following:
1). I have duckDns service setup
2). DNSmasq configured (maybe here is a problem also). My config:
defaults:
8.8.8.8
8.8.4.8
forwards: []
hosts:
host: .duckdns.org
ip: 192.168.1.110
services: []
3). I am able to reach HA from computer (inside network) via https://<IP_of_my_HA>:8123 without any problems
4). I am able to reach HA from mobile app (outside network) via https://.duckdns.org:8123 without any problems. Everything is working also notofications
5). I ma not able to reach HA from mobile app (inside network) via https://<IP_of_my_HA>:8123.
6). I am able to reach HA from mobile using browser (inside network) via https://<IP_of_my_HA>:8123.
As far as I understand it - NAT loopback needs to be supported on my router to reach HA using duckdns locally (which is not the case in my router). I have changed local IP as you proposed and it does not work.
BR,
Aleksander
There is not NAT’ing involved if the DNS setup is pointing correctly to the internal IP.
Try to ping .duckdns.org inside your network to see if the returned IP is the internal one.
My dnsmasq config:
192.168.1.110 - my IP address of HA
DNS addresses - google
Is something missing here?
I saw optional fields in dnsmasq config like “forwards” and “services” but do I need to add it? If yes - how to do this?
I have tried to set Primary DNS on my router to HA address and secondary to my ISP DNS, but then I still do not have access to HA locally using *.duckdns.org:8123.
