Can not access Home Assistant
after i switch my Deco router from wifi router mode to access point i cant access to HA
Monitor still show same fixed previous IP 192.168.68.99//22 (am not sure about /22) is it something wrong with my router or not cause after i search for solution every got 192.168.x.x/24 not 22
try to log in with homeassitant.local:8123 also not work
on my Deco config page it no show ID of HA that but on Advanced IP scanner it show same IP which is 192.168.68.99 so am not really sure how to access or what should i do next
subnet 255.255.255.0
network info host_internet false supervisor_internet false
subnet
Try accessing by ip, not dns name. 255.255.255.0 is /24 not /22.
try
http:// 192. 168. 68. 99 :8123/
still not work but thank for answer
What ip address does the PC your trying to access HA from have? Is it in the 192.168.68.x range. If not, that could be the cause… :expressionless:
With a /22 network in the range you specified you have usable ip addresses from 192.168.68.1 - 192.168.71.254. Your DNS server 192.168.1.1 does not fall into that range. I am guessing you do not have several vlans defined? What did you aim to accomplish changing the mode on the router?
