I made a new install on a rapsberry pi 3 and then all my entity names where gone.
And my Node red logic did not work anymore.
I have soon tried every way to change the entity name for sensors and switches but with no luck.
I have change it in Hassio Customization Gui and in the zwcfg_*.xml.
Tried to add the entity_registry.yaml file but its gone after reboot.
Have rebooted several times.
The “Etities of this node” in Z-Wave Network Management will stay the same and also in NODE RED
I could rename every entity in node red but when the name are so alike.
For example switch.telldus_tzwp100_plugin_switch_switch_4 and switch.telldus_tzwp100_plugin_switch_switch_5.
Hard to keep track of them.
What i understand is that there has been a update that made this mess.
Please help, is there something to do?
