Can not make ZG-204Z works on Z2M
Hi everyone, first of all, 3 months ago, I bought an Luminance motion sensor with Zigbee manufacturer:
_TZE200_3towulqd
This sensor worked very well so i decided to buy a new one, this time the Zigbee manufacturer was:
_TZE200_bh3n6gk8
But this time, the sensor does not show any illuminance,
    "linkquality": 200,
    "occupancy": true,
    "sensitivity": "medium",
    "battery": 100,
    "illuminance": null,
    "illuminance_interval": 1,
    "keep_time": "10"
Have any of you got this illuminance sensor working in Z2M?
Hello uidee.dev,
IF the hardware allows it in the new one (And it very well might not) then you can tweak the quirk to make it work…
Zigbee2MQTT
Hi thank you, I have found that when I click into “generate_external_definition” in the extend line, the illuminance variaable is not found
    extend: [m.iasZoneAlarm({"zoneType":"generic","zoneAttributes":["alarm_1","alarm_2","tamper","battery_low"]}), m.battery()],
But for example, the code on the sensor that works great is different:
extend: [m.iasZoneAlarm({"zoneType":"generic","zoneAttributes":["alarm_1","alarm_2","tamper","battery_low"]}), m.battery(), m.illuminance()],
The problem now is: If i go to z2m tuya code, i can verify that it has the illuminance datapoint:
        fingerprint: tuya.fingerprint("TS0601", ["_TZE200_3towulqd", "_TZE200_1ibpyhdc", "_TZE200_bh3n6gk8", "_TZE200_ttcovulf", "_TZE200_gjldowol"]),
        model: "ZG-204ZL",
        vendor: "Tuya",
        description: "Luminance motion sensor",
        fromZigbee: [tuya.fz.datapoints],
        toZigbee: [tuya.tz.datapoints],
        exposes: [
            e.occupancy(),
            e.illuminance().withUnit("lx"),
            e.battery(),
            e
                .enum("sensitivity", ea.STATE_SET, ["low", "medium", "high"])
                .withDescription("PIR sensor sensitivity (refresh and update only while active)"),
            e
                .enum("keep_time", ea.STATE_SET, ["10", "30", "60", "120"])
                .withDescription("PIR keep time in seconds (refresh and update only while active)"),
            e
                .numeric("illuminance_interval", ea.STATE_SET)
                .withValueMin(1)
                .withValueMax(720)
                .withValueStep(1)
                .withUnit("minutes")
                .withDescription("Brightness acquisition interval (refresh and update only while active)"),
        meta: {
            tuyaDatapoints: [
                [1, "occupancy", tuya.valueConverter.trueFalse0],
                [4, "battery", tuya.valueConverter.raw],
                    9,
                    "sensitivity",
                    tuya.valueConverterBasic.lookup({
                        low: tuya.enum(0),
                        medium: tuya.enum(1),
                        high: tuya.enum(2),
                    10,
                    "keep_time",
                        "10": tuya.enum(0),
                        "30": tuya.enum(1),
                        "60": tuya.enum(2),
                        "120": tuya.enum(3),
                [12, "illuminance", tuya.valueConverter.raw],
                [102, "illuminance_interval", tuya.valueConverter.raw],
