Can not see z2m devices to make dash boards
I’ve been using ZHA and a HubZ ZigBee HUSBZB-1 coordinator. It works fine but it is old.
I am trying to set up a second zigbee network on another channel using a slzb-06m. The Z2M dashboard shows my test device and I can turn it on and off so that part works.
I can’t find the device to add to my HA dashboards.
Looking at the Mosquito add on in my HA install I see these log entries
# log of mosquitto starting up
[14:01:22] INFO: Starting NGINX for authentication handling...
s6-rc: info: service legacy-services successfully started
[14:01:22] INFO: Starting mosquitto MQTT broker...
2025-09-27 14:01:22: Warning: Mosquitto should not be run as root/administrator.
2025-09-27 14:01:22: mosquitto version 2.0.22 starting
2025-09-27 14:01:22: Config loaded from /etc/mosquitto/mosquitto.conf.
2025-09-27 14:01:22: Loading plugin: /usr/share/mosquitto/go-auth.so
2025-09-27 14:01:22:  ├── Username/password checking enabled.
2025-09-27 14:01:22:  ├── TLS-PSK checking enabled.
2025-09-27 14:01:22:  └── Extended authentication not enabled.
2025-09-27 14:01:22: Opening ipv4 listen socket on port 1883.
2025-09-27 14:01:22: Opening ipv6 listen socket on port 1883.
2025-09-27 14:01:22: Opening websockets listen socket on port 1884.
2025-09-27 14:01:22: mosquitto version 2.0.22 running
2025-09-27 14:01:23: New connection from ::1:53844 on port 1883.
2025-09-27 14:01:23: Client <unknown> disconnected due to protocol error.
2025-09-27 14:01:23: New connection from 192.168.1.126:62997 on port 1883.
2025-09-27 14:01:23: New client connected from 192.168.1.126:62997 as mqtt-explorer-3ef3f172 (p2, c1, k60, u'wes').
[14:01:23] INFO: Successfully send discovery information to Home Assistant.
[14:01:24] INFO: Successfully send service information to the Supervisor.
2025-09-27 14:02:34: New connection from 172.30.33.10:40304 on port 1883.
2025-09-27 14:02:34: New client connected from 172.30.33.10:40304 as mqttjs_4c019a0e (p2, c1, k60, u'addons').
2025-09-27 14:04:55: New connection from 172.30.32.2:34150 on port 1883.
2025-09-27 14:04:55: Client <unknown> closed its connection.
2025-09-27 14:05:36: Client mqtt-explorer-3ef3f172 disconnected.
2025-09-27 14:05:38: New connection from 192.168.1.126:63197 on port 1883.
2025-09-27 14:05:38: New client connected from 192.168.1.126:63197 as mqtt-explorer-3ef3f172 (p2, c1, k60, u'wes').
2025-09-27 14:06:55: New connection from 172.30.32.2:43758 on port 1883.
2025-09-27 14:06:55: Client <unknown> closed its connection.
2025-09-27 14:08:55: New connection from 172.30.32.2:58352 on port 1883.
2025-09-27 14:08:55: Client <unknown> closed its connection.
2025-09-27 14:10:55: New connection from 172.30.32.2:44238 on port 1883.
2025-09-27 14:10:55: Client <unknown> closed its connection.
So I’m curious what belongs to 172.30.32.2
~ docker ps -q | xargs -I {} docker inspect --format '{{ .Name }}  {{range .NetworkSettings.Networks}} - {{.IPAddress}}{{end}}' {}
/addon_core_mosquitto   - 172.30.33.0
/addon_45df7312_zigbee2mqtt   - 172.30.33.10
/addon_a0d7b954_wireguard   - 172.30.33.9
/addon_a0d7b954_sqlite-web   - 172.30.33.8
/addon_cebe7a76_hassio_google_drive_backup   - 172.30.33.7
/addon_a0d7b954_logviewer   - 172.30.33.6
/addon_core_configurator   - 172.30.33.5
/addon_a0d7b954_grafana   - 172.30.33.4
/addon_a0d7b954_influxdb   - 172.30.33.3
/addon_5c53de3b_esphome   -
/addon_core_zwave_js   - 172.30.33.2
/addon_a0d7b954_ssh   -
/addon_core_matter_server   -
/addon_a0d7b954_chrony   - 172.30.33.1
/hassio_multicast   -
/hassio_audio   - 172.30.32.4
/hassio_dns   - 172.30.32.3
/hassio_cli   - 172.30.32.5
/homeassistant   -
/hassio_supervisor   - 172.30.232.2 - 172.30.32.2
/hassio_observer   - 172.30.32.6
hassio_supervisor appears to be it. I’m thinking that is my problem but I have no clue as how to fix it.
Help please.
I understand what you are saying, I’m not writing an automation, I don’t see my smart outlet as a device or entity in Home Assistant, only in z2m.
Settings → Devices & Services → MQTT → Your device → Entities
I see that I have MQTT pointing to a broker on my pc that I was doing some node red stuff with and brought in some sensor readings to HA from my diy sensors.
MQTT needs to be pointed at the broker on my HA box and it doesn’t look like I can use two brokers.
Sorry if this is rambling, it is late. I reconfigured pointing to the broker on the HA box and I saw the devices I paired to z2m.
You can bridge them.
That was the clue I needed. I have things working now.
I’ll eventually move my diy sensors over to using the broker on HA but that will be when the snow is on the ground and I’m stuck inside. I may convert them to esphome.
