It is possible?
It would be very helpful to improve reliability (for example my wife changed phone last week and I was wondering if i have to change all device tracker for the new one or I can simply use person sensor.
Thank you in advance
It is possible?
You can use any entity you want to trigger.
Iām not sure if that actually works, the āpersonā entity does not have location directly but probably one of the entities returned as the āsourceā.
Update
I found what was causing the problem on my end, the Unify and IOS presence detection were overriding the iPhone ādevice_trackerā entity since both generate one with same name. I have to rename the ID in the IOS app and add both for that person
. Now I get the coordinates.
Thatās not correct. If I click on my āpersonā it shows my gps position right now as Iām away from home. I also use the person in the travel time here-now tracker integration
Youāre right. I found what was causing the problem on my end. Comment updated. Thank you!
Thereās a hierarchy for personā¦ gps should override the others I think. I had multiple entities in my person and I ended up removing one that always was throwing off the location and saying I was home when other trackers correctly marked me away. It can be trial and error.
Yes thatās correct. In my case the entity created by the unify
integration was overriding the one created by the ios
platform. So I had just one device_tracker
entity. After renaming the ios
one in the app, I have now two device_tracker
entities in the person
one and the GPS one correctly overrides the unify
one. Thanks.
