Newbie here. I’m trying to add IFTTT integration from the HA console. I get the “Set up the IFTTT Webhook Applet” pop-up, and when I click Submit I get “Unknown error occurred. Are you sure you want to set up IFTTT?”
The HA log is below.
Error handling request
File "/usr/local/lib/python3.9/site-packages/aiohttp/web_protocol.py", line 422, in _handle_request
resp = await self._request_handler(request)
File "/usr/local/lib/python3.9/site-packages/aiohttp/web_app.py", line 499, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.9/site-packages/aiohttp/web_middlewares.py", line 119, in impl
return await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 60, in security_filter_middleware
File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 89, in forwarded_middleware
File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 24, in request_context_middleware
File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 78, in ban_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 144, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 135, in handle
result = await result
File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 155, in post
return await super().post(request, flow_id)
File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 63, in wrapper
result = await method(view, request, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 109, in post
result = await self._flow_mgr.async_configure(flow_id, data)
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 202, in async_configure
result = await self._async_handle_step(flow, cur_step["step_id"], user_input)
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 260, in _async_handle_step
result: FlowResult = await getattr(flow, method)(user_input)
File "/usr/src/homeassistant/homeassistant/helpers/config_entry_flow.py", line 174, in async_step_user
webhook_url = self.hass.components.webhook.async_generate_url(webhook_id)
File "/usr/src/homeassistant/homeassistant/components/webhook/__init__.py", line 70, in async_generate_url
get_url(hass, prefer_external=True, allow_cloud=False),
File "/usr/src/homeassistant/homeassistant/helpers/network.py", line 116, in get_url
raise NoURLAvailableError
homeassistant.helpers.network.NoURLAvailableError
I also have external URL set up correctly.
default_config:
external_url: https://my-domain-name.duckdns.org
internal_url: http://192.168.40.4:8123
Please advice.
