Just installed the latest version of HASS.io on a Pi 3. I’ve added the Configuator add on. Funny thing is when I try to edit the config file with the configuration box, the save button is grayed out (disabled). And when I start the Addon I get the following in the log:
Yes, what I’m trying to say, when ever I change the user and password, the save button grays out. Can’t save this edited configuration. This is maddening!
Yes I put the username and password in quotes. The problem is that I can’t save it because the save button become disabled. The save button disables as soon as you make changes to the configuration.
Wow, I figured it out. Would you believe the iphone’s Quotation is slightly different than the one for the configuration. So I just copied and pasted the quotation.
Copy & paste is generally suboptimal on mobile devices with the configurator. The editor-software that’s being used in the background has this issue, and it’s having that for quite some time now. So ideally you should be using a regular computer if possible.
Yeah, but I can access the web interface on my laptop although. I don’t understand why I can’t. I connect to the same wifi that the pi uses. Any ideas?
