Can we make input_datetime tz aware?
I may not fully understand this, but I’ve been working with/studying datetime a bit now trying to build an automation, using an input_datetime as a storage slot for last_updated values for entities for later comparisons. I wanted to put both the UTC and LOCAL times in the Logbook for debugging, but it appears the input_datetime is ‘naive’ and has no tzinfo, so it is not easily converted using the standard supplied methods. Would it make sense to be able to make intput_datetime entites tz aware? It could be an option in the config, which would allow us to use the supplied methods.
Although, maybe I’m missing something in my template tests. I tried to do several variations of the following, which produced errors:
UndefinedError: 'str object' has no attribute 'tzinfo' with
{{ states('input_datetime.XXX').tzinfo() }} or
UndefinedError: 'homeassistant.helpers.template.TemplateState object' has no attribute 'tzinfo' with
{{ states.input_datetime.XXX.tzinfo() }}
I was trying to use .astimezone() to get local time from UTC, which is what states('input_datetime.XXX') produces.
EDIT: however, I just found that THIS works!
{{ states.input_datetime.XXX.last_changed.astimezone() }}
So what is stored in the object is just a string then?
Although, this:
{{ now() - as_datetime(states('input_datetime.XXX'))
produces this:
TypeError: can't subtract offset-naive and offset-aware datetimes
The state value of any entity is a string.
If the input_datetime contains a date and time this will convert it from a string to an offset-aware datetime object.
{{ as_datetime(states('input_datetime.test')).astimezone() }}
On a separate note, the value of any entity’s last_changed property is an offset-aware datetime object (and it’s in UTC).
Perfect! This is LOCAL time, right? I could never get this ‘concept’ to work, and I could swear I tried this rendition. I could never get as_datetime to work for anything, so I gave up on it. As you indicated, I was able to get the states.MY_ENTITY.last_updated.astimezone() to work, so I just converted it to LOCAL before storing it in the input_datetime and was then able to compare it successfully to the now() after converting both with as_timestamps(). I beat my head against a wall for hours.
BTW, where are the tz= parameters to astimezone() defined? If I wanted to designate Alaska, where would I find what to enter?
Thanks (again) for the assist! Maybe I should just start paying you for some tutoring. :wink:
You can compare the value of now() to an offset-aware datetime object (without first converting both to timestamps).
If Alaska is your local time then astimezone() will add the correct local timezone offset to an offset-naive datetime object (assuming Home Assistant’s timezone setting is correct).
