I’m curious if I can nest a grid layout inside a grid layout. Picture a 3x3 grid. In row 1 column 1, I want to have another 3x3 grid. Two reasons:
- indepdencence – I want to create separate .yaml for the nested grid-layout so I can swap out the code by including different .yaml… Think nested 3x3 Grid A.yaml and nested 3x3 Grid B.yaml. Then I can create a condition card that will swap them depending on conditions.
- Cleaner code - Keeping this code in separate .yaml files stops me from having one giant 2K lines .yaml file for my dashboard.
- independent column control. I want the exterior r1c1 to be 1/3 of the screen but I want the interior grid to be 1fr 3fr 1fr but still all fit within the 1/3 of the screen.
I’ve tried a variety of configurations but hitting a wall so I wanted to know if it’s even possible before I beat my head against the wall too many more times.
Are you talking about a Sections layout view in a yaml-managed dashboard?
Each section uses a Grid card where every child card can have some grid options (number of rows/columns).
You can create a Grid card as a child card, but sub-childs cannot have those grid options (like a standalone Grid card on a masonry layout view).
Perhaps you can use a custom:layout-card with a grid layout (supporting all css grid properties) instead of the Grid card, never tried myself.
So, in general the answer is “yes, you can use a grid inside a grid”.
No I’m talking about an external .yaml single pane dashboard where that looks like this:
kiosk_mode:
hide_header: true
- type: custom:grid-layout
theme: 'LCARS TNG'
path: default
layout:
#default
grid-gap: var(--custom-layout-card-padding)
grid-template-columns: 1.5fr 1fr 1fr 8.5fr
grid-template-rows: auto auto auto 1fr auto
grid-template-areas: |
"header header header header"
"scanner systitle options title"
"datapanel sysops controls sysinfo"
"datapanel sysops memory sysinfo"
"datarows command sensormode starmap"
cards:
# SCANNER #
view_layout:
grid-area: scanner
layout:
display: grid
grid-template-columns: 1fr 8fr 1fr
grid-template-rows: 1fr 1fr 1fr
"left center right"
"left center right"
"left center right"
cards:
If this is a yaml-mode dashboard - definitely you can use «include» for any dictionary or list.
If this is not answering your question - suggest to elaborate which part of your yaml exampl you wish to import.
BTW - what you are calling “grid layout” is a custom layout-card.
The “custom:grid-layout” may only be used for a VIEW, and cards cannot be declared as “custom:grid-layout”, they can only be “custom:layout-card” with defined grid layout. Check docs for the layout-card.
