Can You Switch a Moes MS-105Z from Dimming to Simple On/Off?
Using a Moes MS-105Z Zigbee dimmer with Home Assistant and standard dumb rocker switches.
Is there an attribute I overlooked that changes the switch type from momentary to toggle?
The switch input treats a normal state change like a long press, which causes continuous dimming instead of a simple toggle. When I flip the switch up, it starts dimming up and down. When I flip it down, it sets the brightness.
In some rooms I would like toggle control. Flip the switch and the light changes state on or off, regardless of the current light state or switch position.
