Hi there.
I’m in the process of interfacing with a Mercedes-Benz PSM. The PSM is actually a PLC with at least two canbuses. One for the connection to the card (interior can B), and the other (ABH-CAN) for upfitters.
I’ve decided to interface my HMI (a waveshare touch screen) via ABH-CAN.
Getting the CANbus online is not an issue. I’ve also been able to decode most of the frames data.
The payload (data) of the can_frame is eight bytes long.
- Byte 1: I/O-bits 1-4
- Byte 2: I/O-bits 5-8
- Byte 3: Databyte 1
- Byte 4: Databyte 2
- Bytes 5-6: Word1
- Bytes 7-8: Word2
The input-bits are coded with two bits; - 00 = off
- 01 = on
- 11 = Signal not available
The input-bits are LSB, so to send four input-bits on, off, off, off (as 1, 0, 0, 0) would be in 00 00 00 01, and thus 0x01.
In a similar manner, off, on, off, off would be 00 00 01 00 → 0x04.
The same analogy goes when the PSM transmits data on the ABH-CAN
Ideally I’d have some bits transferred via the can-bus, but also bytes (battery voltage, temperatures etc). But I have absolutely NO idea how to split the can-data in a reasonable manner to variables to use for switches/sensors
Sure, it starts with
canbus:
- platform: esp32_can
tx_pin: GPIO15
rx_pin: GPIO16
can_id: 6
use_extended_id: true
bit_rate: 125kbps
on_frame:
- can_id: 6
can_id_mask: 1111111
use_extended_id: True
then:
And I draw a blank ![]()
Any help is appreciated. I’d need the eight I/O bits to switches and the databytes for sensors
