Cancel delay in Automation Action
is there a way to stop the delay and drop action after?
example:
  - alias: Kueche Fenster offen iOS
      - platform: state
        entity_id: group.Fensterkontakt_Kueche
        to: 'on'
      - delay: "00:{{ states.sensor.window_timer.state | int }}:00"
      - service: notify.ios_iphonesk
          title: "Küche Fenster {{relative_time(states.group.Fensterkontakt_Kueche.last_changed).replace('hours','h').replace('minutes','min').replace('seconds','sek')}} geöffnet!"
          message: "Die Temperatur im Küche beträgt: {{states.climate.kuche.attributes.current_temperature}}°
          \r\nund die Luftfeuchtigkeit: {{states.sensor.kuche_humidity.state}}%"
            push:
              badge: 0
              category: "reminder_kueche"
normal: you open the window and you get a push notification after a time
but if you close the window it should stop and no message should appear.
So Action musst be aborded.
thanks for help
Steve
Add a condition after the delay that checks the state of the window.
The automation will only continue if the condition is true.
      - condition: state
        entity_id: sensor.your_window_sensor
        state: 'open'
            push:
              badge: 0
cool thanks
I didn’t know that this is possible
