Hi guys,
I’m a bit panicking because my Home Assistant setup (Rasp Pi 4) seems to have a serious problem. First of all: I can’t access via web UI (http://homeassistant.local:8123). It’s stuck at the starting screen which says “Home Assistant is a Project by the Open Home Foundation”.
But I can access via Companion app which is now my only way to check logs and other things. I find a lot of troubling issues. For example, I’m not able to restart Home Assistant. Error message:
the system cannot restart because the configuration is not valid: Error loading /config/configuration.yaml: [Errno 5] I/O Error: ‘config/configuration.yaml’
I guess this might be the main issue here. Somehow the configuration.yaml seems to be gone? I also can’t access yaml files with Studio Code Server (it shows a blank page).
I searched the forum and found out, that Errno 5 usually relates to a backup error. This is also true, as the latest backups (System > Backups) failed. An hour ago 3 backups were listed here (saved on system) but when I tried to download them to my phone to be sure to keep them they weren’t found and now they aren’t shown anymore.
Furthermore, trying to access the Add-on tab shows a blank page with “Troubleshoot”-message. It tells me to check the Observer, restart the Host (I can’t) and check the system state (link leads to a blank browser page).
Also, every single automation has a warning in their details. It says:
The automation cannot be edited in the user interface, because it isn’t saved in automations.yaml or doesn’t have an ID.
I’m relatively new to Home Assistant and I don’t understand the error logs. I also don’t know where to start digging.
What did break the thing: I don’t know. Yesterday everything seemed fine, I worked on a few automations (web interface and Companion) and checked them hours later. I didn’t install any new Add-ons, services or integrations. Today I stumbled over all these errors.
I have backups on Google drive from Dec 3rd and before, but I have worked a lot on Home Assistant since then. Unfortunately I didn’t realize these daily updates stopped working.
Does someone has some advice?
System Information:
System Information
version | core-2025.12.2
installation_type | Home Assistant OS
dev | false
hassio | true
docker | true
container_arch | aarch64
user | root
virtualenv | false
python_version | 3.13.9
os_name | Linux
os_version | 6.12.47-haos-raspi
arch | aarch64
timezone | Europe/Berlin
config_dir | /config
Home Assistant Community Store
GitHub API | ok
GitHub Content | ok
GitHub Web | ok
HACS Data | ok
GitHub API Calls Remaining | 5000
Installed Version | 2.0.5
Stage | running
Available Repositories | 2488
Downloaded Repositories | 7
Home Assistant Cloud
logged_in | true
subscription_expiration | 1. Januar 2018 um 01:00
relayer_connected | false
relayer_region | null
remote_enabled | false
remote_connected | false
alexa_enabled | true
google_enabled | true
cloud_ice_servers_enabled | true
remote_server | null
certificate_status | null
instance_id | e4488def5d7d4fba977098c9d1c1b224
can_reach_cert_server | ok
can_reach_cloud_auth | ok
can_reach_cloud | ok
Home Assistant Supervisor
host_os | Home Assistant OS 16.3
update_channel | stable
supervisor_version | supervisor-2025.12.3
agent_version | 1.7.2
docker_version | 28.3.3
disk_total | 56.6 GB
disk_used | 22.3 GB
nameservers | 192.168.178.1
healthy | true
supported | true
host_connectivity | true
supervisor_connectivity | true
ntp_synchronized | true
virtualization |
board | rpi5-64
supervisor_api | ok
version_api | ok
installed_addons | Matter Server (8.1.1), Advanced SSH & Web Terminal (22.0.3), Studio Code Server (6.0.1), Cloudflared (7.0.1), Home Assistant Google Drive Backup (0.112.1), Mosquitto broker (6.5.2), eufy-security-ws (1.9.3), Govee to MQTT Bridge (2025.11.25-60a39bcc)
Dashboards
dashboards | 4
resources | 4
views | 5
mode | storage
Network Configuration
adapters | lo (disabled), end0 (enabled, default, auto), hassio (disabled), docker0 (disabled), veth18bfe6e (disabled), veth10a3e94 (disabled), veth149cedf (disabled), vethc088bcb (disabled), veth2a1f925 (disabled), vethc9d8ccb (disabled), veth37d89f4 (disabled), vetha11ccd4 (disabled), veth50d5b7e (disabled)
ipv4_addresses | lo (127.0.0.1/8), end0 (192.168.178.68/24), hassio (172.30.32.1/23), docker0 (172.30.232.1/23), veth18bfe6e (), veth10a3e94 (), veth149cedf (), vethc088bcb (), veth2a1f925 (), vethc9d8ccb (), veth37d89f4 (), vetha11ccd4 (), veth50d5b7e ()
ipv6_addresses | lo (::1/128), end0 (fe80::657d:809d:c621:3626/64), hassio (fe80::c01e:b1ff:feb3:b56a/64), docker0 (fe80::9890:5eff:fe16:6f7a/64), veth18bfe6e (fe80::7403:35ff:fe89:61db/64), veth10a3e94 (fe80::3021:24ff:fe00:b75e/64), veth149cedf (fe80::98b3:91ff:fea0:60dd/64), vethc088bcb (fe80::d043:24ff:fe15:99b2/64), veth2a1f925 (fe80::5414:1bff:fe50:c543/64), vethc9d8ccb (fe80::bc20:d9ff:feed:2358/64), veth37d89f4 (fe80::f432:8ff:fe4a:8b31/64), vetha11ccd4 (fe80::825:aff:fec7:bea4/64), veth50d5b7e (fe80::9475:72ff:fe60:fe90/64)
announce_addresses | 192.168.178.68, fe80::657d:809d:c621:3626
Recorder
error | failed to load: unknown
Spotify
api_endpoint_reachable | ok
