Hi All,
I’m at my wits end. Seemingly out of the blue, my home assistant instance is no longer accessible. Using home assistant container in docker. There are no errors in my logs, the docker container has network access, I’ve run all the tests on my config. Double checking with a clean ha instance, I can reach 8123 and start the onboarding. Loading my existing instance, nothing…
Any advice on where I should investigate next would be much appreciated. I’m suspecting something in my instance has corrupted, but not sure where to look without any error logs.
Best,
Mark
