Cannot access HA anymore, Supervisor healthy and OK, CLI is fine
I am running HA on Raspberry PI 4 for 2 years and suddenly I cannot access it anylonger.
Here is where I am:
  • remote to HA gives HOST ERROR
  • local (via IP) gives: cannot reach site
  • ping to the PI-4 works and gives me 125ms return latency
  • advance IP scan (app) sees PI-4; WireShark tells me ‘retransmissions’ end ‘reset’ of connection to the PI-4
  • port :4357 (supervisor): all fine and healthy
  • port:7070 (evcc): works fine
  • direct screen/keyboard on PI-4 USB: fine, I get the CLI
    So, it seems that the frontend doesn’t, the backend is fine.
Now my questions:
  1. maybe the SD card is faulty. How can I diagnose via the CLI? Or, can I check it by plugging in on a Windows PC?
  2. Can I restart the frontend in anyway or can I do something to check integrity of the HA installation?
  3. How can I check the network interface from the HA CLI by e.g. ping to another PC?
  4. Any other way to get my HA back working?
Try
ha su repair
ha core rebuild
Result after core rebuild command: ERROR: No home assistant core response, assuming a fatal startup error.
What should I do next?
Now the SD card in the Raspberry PI 4 diesn’t work anymore.
STOP now !
