Cannot access HA on PROXMOX Solved
used this guide first Installing Home Assistant OS using Proxmox 8
**3.1)** To install the Home Assistant OS virtual machine, copy and run the following command in the Proxmox Shell.
bash -c “$(wget -qLO - https://github.com/tteck/Proxmox/raw/main/vm/haos-vm.sh)”
Then tried [os.habitats.tech](https://community.home-assistant.io/u/os.habitats.tech) version
Both installation looks fine, after the 20 minutest configuration
the I check configure from full backup, did upload the backup.tar
should be finisch in 45 Minutes, waiter first time all night, second time over an hour.
Import did not finish. but the ha console came up. The shown address is up, port 8123 is up, But browser chrome say no  data. core log shows a lot of error see attached screen shot
did `ha core logs
ha core rebuild
ha su repair`
then reboot, same problem with the browser
I like to import my old config as a manual rebuild would be a lot of time.
Or someone can give me a hint to migrate the ESXi version build on the ova image in 2019
migrating this does not boot.
otherwise what can I do to export the current config, other than makeing a full backup manualy.
thank for help
my server is a prfession Fujitsu server with dual quadcorde Xenon and 40 GB of RAM
![Bildschirmfoto 2024-04-18 um 17.03.14|690x411](upload://Ac5hUzNMNUQnE3Lrp8SGWOIvQhR.jpeg)
