I’m using a Raspberry Pi 3B which used to set up Home Assistant + Homebridge. So I burned a Hass.io image ( [Raspberry Pi 3 Model B and B+ 32bit] as recommended) with a new SD card. Then insert it into my Pi and power on. Then go to its IP:8123 in browser. Nothing (connection refused). Waited 30 minutes, still nothing.
Then I tried several ways try to figure out the problem. I tried a different SD card, no luck. I tried use Win32DiskImager rather than Etcher on Mac with download the image again, still nothing. Now I wonder if the image file itself is corrupted?
Thanks. But it not working. I’ve done a lot of searching and found quit a lot similar issues. It should not related to IPv6 or network setting. Just a bunch of case with fresh install and cannot get to web UI show up. Web UI appears not running or something blocks browser. No solid solution found so far.
Something appears to be triggering AppArmor.
I ran Hassio on Raspbian Lite for quite a while before I switched to a Home Assistant manual venv installation. I never ran into those issues.
The error you linked to tells me you needed to set the date and time to the current one, not one in the future.
Certificate Authorities do not issue certificates that start validity at a future date. If your machine date is too far in the past it says the certificate is not yet valid.
Setting your date to an incorrect one can cause future issues even though it fixed the current one.
