Cannot add Philips Hue Iris in ZHA
I bought a Hue Iris with the model number 929002376101 but I am struggling to add it to ZHA.
I have no hub from Philips so I tried to reset the lamp via the Hue app by resetting the lamp there. The lamps flashes once but I doesn’t show up in Home Assistant when looking for devices. In the logs I can see the id of the device showing up, but it doesn’t start configuring.
On this site the device is not listed to be compatible with ZHA, however there is an issue on the core repository of home assistant stating the device number, which to me indicates that is should be possible to set up.
For Zigbee I am using a Sonoff Dongle E and currently home assistant version 2024.12.5. Home Assistant is running as the supervised version on my home server.
Not sure if this is the right place for this question, but can someone tell me, what I could do to get the device connected?
