Hello
I have a roller shutter controlled by a Aqara Relay T2 in interlock mode, to which I added a motor encoder using ESPHome rotary encoder component. Both of these parts work perfectly.
The problem is when I try to set the position of the shutter I get “Entity xxxx does not support the cover.set_cover_position action”.
Here is my cover config :
cover:
covers:
volet_roulant:
unique_id: volet_roulant
device_class: shutter
friendly_name: "Volet roulant"
position_template: "{{ states('sensor.shutter_position_volet') }}"
open_cover:
action: switch.turn_on
entity_id: switch.volet_roulant_montee
close_cover:
entity_id: switch.volet_roulant_descente
stop_cover:
action: switch.turn_off
entity_id:
- switch.volet_roulant_descente
- switch.volet_roulant_montee
Form my understanding of the documentation (the Garage door example) it should be enough. Or do I have to define set_cover_position
? if so, how ?
For reference, my ESPHome config :
esphome:
friendly_name: shutter
- platform: rotary_encoder
pin_a: D1
pin_b: D2
unit_of_measurement: "%"
publish_initial_value: True
filters:
- calibrate_linear:
method: exact
datapoints:
- 0 -> 100
- 6 -> 75
- 12 -> 50
- 21 -> 25
- 32 -> 5
- 38 -> 0
Thank you
