Hi!
I’m having some trouble with my knx rgb lights. My controller interprets colors as full brightness, so if I send a [5,0,0] rgb_color, it shows it as [255,0,0], so then I have to send a brightness value of 5 so that it dims the light and shows the desired result.
The main problem is that I cannot send color and brightness in one instruction because then it only changes the brightness value. I have to send the color turn_on instruction first and then the brightness one.
Because there is a slight delay between instructions, I can notice brightness rising when the color instruction is sent and then lowering when the brightness one is sent.
Anyone experiencing the same issue? Am I missing anything in my config or is it a HASS or KNX problem?
- service: light.turn_on
data_template:
entity_id: "{{ light }}"
rgb_color: [255, 128, 64]
brightness: 6
Only changes brightness, does not change color, even when changing the order of color and brightness instructions
data_template:
rgb_color: [4, 2, 1]
data_template:
brightness: 6
changes color at full brightness, equivalent to [255, 128, 64] and then lowers the brightness
