I’m hosting my influxDb on a separate server, but every time I configure the influxdb in HA it fails to connect with an error that no one else seems to have hit.
2024-01-20 14:41:01.949 ERROR (MainThread) [homeassistant.config] Invalid config for 'influxdb' at configuration.yaml, line 9: 'post' is an invalid option for 'influxdb', check: influxdb->post, please check the docs at https://www.home-assistant.io/integrations/influxdb
2024-01-20 14:41:01.950 ERROR (MainThread) [homeassistant.setup] Setup failed for 'influxdb': Invalid config.
I have tried with both 1.8 and 2.x influxdb versions with no luck.
This is the configuration for 1.x influxdb configuration
influxdb:
host: 192.168.68.67
post: 8086
database: homeassistant
username: USERNAME
password: PASSWORD
max_retries: 3
these are the influxdb and chronograf versions being used
influxdb 1.8 102ea8b9b600 9 days ago 307MB
chronograf latest 0d0df6223930 9 days ago 237MB
influxdb latest 7a1b63100937 9 days ago 378MB
Has anyone else hit this?
