I am running 6.16.0, Home Assistant 2022.9.7, Supervisor 2022.10.0, Operating System 9.0, Frontend 20220907.2 - latest. My existing zigbee devices work fine. I went to open phoscon to add a new device and it just shows the phoscon “P” and nothing else. I restarted the addon and hass without any change. I notice that when I open phoscon I get an alert in hass that a device had a failed login. So I’m guessing there is some type of authentication between hass and phoscon that is failing. I don’t see any useful options in the config so I’m not sure what to do further. Here is the log from a recent attempted start up phoscon.
19:46:43:915 Device TTL 3450 s flags: 0x7
19:46:53:414 ZCL attribute report 0xB0CE1814035F4193 for cluster: 0x0006, ep: 0x01, frame control: 0x18, mfcode: 0x0000
19:47:28:865 ZCL attribute report 0xB0CE1814035F42E6 for cluster: 0x0008, ep: 0x01, frame control: 0x18, mfcode: 0x0000
19:47:36:508 ZCL attribute report 0x286D9700010CC7DA for cluster: 0x0402, ep: 0x01, frame control: 0x08, mfcode: 0x0000
172.30.32.2 - - [20/Oct/2022:19:47:40 -0700] "GET /pwa/index.html HTTP/1.1" 200 113226 "https://<redacted>:8123/api/hassio_ingress/Oc436liurPdS2gl6-MHmM_b-1Li63Ij3RDdyQUthlo0/ingress.html" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/106.0.0.0 Safari/537.36"
172.30.32.2 - - [20/Oct/2022:19:47:41 -0700] "GET /pwa/login.html?1666320460403= HTTP/1.1" 200 27057 "https://<redacted>:8123/api/hassio_ingress/Oc436liurPdS2gl6-MHmM_b-1Li63Ij3RDdyQUthlo0/pwa/index.html" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/106.0.0.0 Safari/537.36"
172.30.32.2 - - [20/Oct/2022:19:47:42 -0700] "GET /api/config HTTP/1.1" 200 265 "https://<redacted>:8123/api/hassio_ingress/Oc436liurPdS2gl6-MHmM_b-1Li63Ij3RDdyQUthlo0/pwa/login.html?1666320460403" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/106.0.0.0 Safari/537.36"
19:47:43:915 Device TTL 3390 s flags: 0x7
172.30.32.2 - - [20/Oct/2022:19:47:46 -0700] "GET /pwa/login.html?1666320465513= HTTP/1.1" 200 27057 "https://<redacted>:8123/api/hassio_ingress/Oc436liurPdS2gl6-MHmM_b-1Li63Ij3RDdyQUthlo0/pwa/index.html" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/106.0.0.0 Safari/537.36"
172.30.32.2 - - [20/Oct/2022:19:47:47 -0700] "GET /pwa/login.html?1666320466398= HTTP/1.1" 200 27057 "https://<redacted>:8123/api/hassio_ingress/Oc436liurPdS2gl6-MHmM_b-1Li63Ij3RDdyQUthlo0/pwa/index.html" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/106.0.0.0 Safari/537.36"
19:47:51:907 GW firmware version shall be updated to: 0x26720700
