I’ve wasted a whole day chatting chatGPT with no luck…
I’ve purchased home assistant green.
Installed letsencrypt addon, didn’t succeed.
Installed duckdns, registered a domainm provide the token, the log says that the certs exist but i cannot find them, not even when i manually created /ssl and /config/ssl:
- Checking domain name(s) of existing cert… unchanged.
- Checking expire date of existing cert…
- Valid till May 1 06:58:05 2025 GMT (Longer than 30 days). Skipping renew!
find / -name “ssl”
/root/ssl
/etc/ssl
/homeassistant/ssl
/ssl
find / -name “*.pem”
/usr/lib/python3.12/site-packages/pip/_vendor/certifi/cacert.pem
/etc/ssl1.1/cert.pem
/etc/ssl/cert.pem
Then i thought it may be related to the fact that i first installed let’sencrypt addon and maybe there is some conflict between them, but nothing has changed when i uninstalled letsencrypt.
Final goal is to have the ability to access ha from an external address using https.
Any idea?
