Hello Community,
I would like to switch from a Docker Installation on my Synology to a full installation in a Virtual Machine.
Problem: it does not get an IP.
I tried so much but still no IP.
- Tried .qcow2, vmdk from home-assistant and from github
- tried creating a Linux VM
- Tried e1000, virtio and rtl8139 network model
It all looks fine. Home Assistant is running. Network says connected. I do not know where to look anymore
I have to “Force shutdown” it since normal shutdown will have no effect (I assume it is because it is waiting for an IP)
If I connect to it, it says “Booting from Hard Dik…” and I think here might be the problem. So I downloaded again the qcow2 (this time from github, think the first time it came from home-assistant). Added the image and used it in creating the VM. Still no IP…
Create a VM directly from a downloaded .ova file. Still no change.
Any idea what I am doing wrong. Ask me any question. I feel I tried it all.
