Cannot get network information
EDIT: after several hours it apparently sorted itself out. It was working when i came back to check on it
I just did a fresh install via “method 2” in the guide for installing HAOS on a mini pc. Balena etcher to put the HAOS image directly on a flash drive and boot from that.
I have now tried restarting several times, and reflashing my boot media. It keeps getting stuck during start up.
The observer shows:
Supervisor:Connected
Supported:Processing…
Healthy:Processing…
The log from the webui shows:
2025-03-11 21:44:34.355 INFO (SyncWorker_0) [supervisor.docker.manager] Starting homeassistant
2025-03-11 21:45:54.012 INFO (MainThread) [supervisor.os.manager] Detect Home Assistant Operating System 14.2 / BootSlot A
2025-03-11 21:46:13.377 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/5c53de3b repository
2025-03-11 21:46:13.377 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/core repository
2025-03-11 21:46:13.378 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/d5369777 repository
2025-03-11 21:46:13.379 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/a0d7b954 repository
2025-03-11 21:46:13.679 INFO (MainThread) [supervisor.store] Loading add-ons from store: 81 all - 81 new - 0 remove
2025-03-11 21:46:13.693 INFO (MainThread) [supervisor.addons.manager] Found 0 installed add-ons
2025-03-11 21:46:13.707 INFO (MainThread) [supervisor.backups.manager] Found 0 backup files
2025-03-11 21:46:13.707 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
2025-03-11 21:46:13.707 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
2025-03-11 21:46:13.707 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state setup
2025-03-11 21:46:13.708 INFO (MainThread) [supervisor.resolution.checks.base] Run check for detached_addon_missing/addon
2025-03-11 21:46:13.708 INFO (MainThread) [supervisor.resolution.checks.base] Run check for detached_addon_removed/addon
2025-03-11 21:46:13.708 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
2025-03-11 21:46:13.708 INFO (MainThread) [supervisor.resolution.checks.base] Run check for disabled_data_disk/system
2025-03-11 21:46:13.708 INFO (MainThread) [supervisor.resolution.check] System checks complete
2025-03-11 21:46:13.708 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state setup
2025-03-11 21:46:13.708 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2025-03-11 21:46:13.708 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - setup
2025-03-11 21:46:13.709 INFO (MainThread) [__main__] Running Supervisor
2025-03-11 21:46:16.291 INFO (MainThread) [supervisor.os.manager] Rauc: slot A - activated slot kernel.0, marked slot kernel.0 as good
2025-03-11 21:46:16.306 INFO (MainThread) [supervisor.supervisor] Fetching AppArmor profile https://version.home-assistant.io/apparmor_stable.txt
2025-03-11 21:46:17.759 INFO (MainThread) [supervisor.host.apparmor] Adding/updating AppArmor profile: hassio-supervisor
2025-03-11 21:46:17.822 INFO (MainThread) [supervisor.supervisor] Update Supervisor to version 2025.03.2
2025-03-11 21:46:17.822 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/amd64-hassio-supervisor with tag 2025.03.2.
2025-03-11 21:47:56.397 INFO (MainThread) [supervisor.misc.scheduler] Shutting down scheduled tasks
2025-03-11 21:47:56.399 INFO (MainThread) [supervisor.docker.monitor] Stopped docker events monitor
2025-03-11 21:47:56.399 INFO (MainThread) [supervisor.api] Stopping API on 172.30.32.2
2025-03-11 21:47:59.024 INFO (MainThread) [supervisor.hardware.monitor] Stopped Supervisor hardware monitor
2025-03-11 21:47:59.029 INFO (MainThread) [supervisor.dbus.manager] Closed conection to system D-Bus.
2025-03-11 21:47:59.036 INFO (MainThread) [supervisor.core] Supervisor is down - 0
2025-03-11 21:47:59.037 INFO (MainThread) [__main__] Closing Supervisor
[04:48:06] WARNING: Halt Supervisor
[04:48:09] INFO: Supervisor restart after closing
s6-rc: info: service legacy-services: stopping
[04:48:09] INFO: Watchdog restart after closing
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
Failed to fetch logs
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/udev.sh
[01:12:30] INFO: Using udev information from host
cont-init: info: /etc/cont-init.d/udev.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun supervisor (no readiness notification)
services-up: info: copying legacy longrun watchdog (no readiness notification)
[01:12:30] INFO: Starting local supervisor watchdog...
s6-rc: info: service legacy-services successfully started
2025-03-13 01:12:33.957 INFO (MainThread) [__main__] Initializing Supervisor setup
2025-03-13 01:12:33.966 INFO (MainThread) [supervisor.docker.network] Can't find Supervisor network, creating a new network
2025-03-13 01:12:39.347 INFO (MainThread) [supervisor.bootstrap] Setting up coresys for machine: generic-x86-64
2025-03-13 01:12:39.352 INFO (MainThread) [supervisor.docker.supervisor] Attaching to Supervisor ghcr.io/home-assistant/amd64-hassio-supervisor with version 2024.12.3
2025-03-13 01:12:39.352 INFO (MainThread) [supervisor.docker.supervisor] Connecting Supervisor to hassio-network
2025-03-13 01:12:42.074 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state initialize
2025-03-13 01:12:42.076 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2025-03-13 01:12:42.076 INFO (MainThread) [__main__] Setting up Supervisor
2025-03-13 01:12:43.804 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
2025-03-13 01:12:43.854 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
2025-03-13 01:12:43.855 INFO (MainThread) [supervisor.dbus.manager] Connected to system D-Bus.
2025-03-13 01:12:43.855 INFO (MainThread) [supervisor.dbus.agent] Load dbus interface io.hass.os
2025-03-13 01:12:43.855 INFO (MainThread) [supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1
2025-03-13 01:12:43.856 INFO (MainThread) [supervisor.dbus.logind] Load dbus interface org.freedesktop.login1
2025-03-13 01:12:43.856 INFO (MainThread) [supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManager
2025-03-13 01:12:43.856 INFO (MainThread) [supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauc
2025-03-13 01:12:43.856 INFO (MainThread) [supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1
2025-03-13 01:12:43.856 INFO (MainThread) [supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1
2025-03-13 01:12:43.857 INFO (MainThread) [supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1
2025-03-13 01:12:43.950 INFO (MainThread) [supervisor.host.services] Updating service information
2025-03-13 01:12:43.953 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
2025-03-13 01:12:43.958 WARNING (SyncWorker_0) [supervisor.host.sound] Can't update PulseAudio data: Failed to connect to pulseaudio server
2025-03-13 01:12:45.472 INFO (MainThread) [supervisor.host.network] Updating local network information
2025-03-13 01:12:45.546 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
2025-03-12 18:12:47.982 INFO (MainThread) [supervisor.docker.monitor] Started docker events monitor
2025-03-12 18:12:47.982 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
2025-03-12 18:13:01.834 INFO (MainThread) [supervisor.docker.interface] Found ghcr.io/home-assistant/amd64-hassio-cli versions: [<AwesomeVersion CalVer '2024.09.0'>]
2025-03-12 18:13:01.841 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-cli with version 2024.09.0
2025-03-12 18:13:15.743 INFO (MainThread) [supervisor.plugins.cli] Starting CLI plugin
2025-03-12 18:14:05.378 INFO (MainThread) [supervisor.docker.cli] Starting CLI ghcr.io/home-assistant/amd64-hassio-cli with version 2024.09.0 - 172.30.32.5
2025-03-12 18:14:07.379 INFO (MainThread) [supervisor.docker.interface] Found ghcr.io/home-assistant/amd64-hassio-dns versions: [<AwesomeVersion CalVer '2024.12.0'>]
2025-03-12 18:14:07.388 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-dns with version 2024.12.0
2025-03-12 18:14:07.708 INFO (MainThread) [supervisor.plugins.dns] Starting CoreDNS plugin
2025-03-12 18:15:32.192 INFO (MainThread) [supervisor.docker.dns] Starting DNS ghcr.io/home-assistant/amd64-hassio-dns with version 2024.12.0 - 172.30.32.3
2025-03-12 18:15:32.196 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
2025-03-12 18:15:32.301 INFO (MainThread) [supervisor.docker.interface] Found ghcr.io/home-assistant/amd64-hassio-audio versions: [<AwesomeVersion CalVer '2023.12.0'>]
2025-03-12 18:15:32.309 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-audio with version 2023.12.0
2025-03-12 18:15:32.378 INFO (MainThread) [supervisor.plugins.audio] Starting Audio plugin
2025-03-12 18:17:01.067 INFO (MainThread) [supervisor.docker.audio] Starting Audio ghcr.io/home-assistant/amd64-hassio-audio with version 2023.12.0 - 172.30.32.4
2025-03-12 18:17:01.131 INFO (MainThread) [supervisor.docker.interface] Found ghcr.io/home-assistant/amd64-hassio-observer versions: [<AwesomeVersion CalVer '2023.06.0'>]
2025-03-12 18:17:01.138 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-observer with version 2023.06.0
2025-03-12 18:17:01.320 INFO (MainThread) [supervisor.plugins.observer] Starting observer plugin
2025-03-12 18:18:13.845 INFO (MainThread) [supervisor.docker.observer] Starting Observer ghcr.io/home-assistant/amd64-hassio-observer with version 2023.06.0 - 172.30.32.6
2025-03-12 18:18:13.924 INFO (MainThread) [supervisor.docker.interface] Found ghcr.io/home-assistant/amd64-hassio-multicast versions: [<AwesomeVersion CalVer '2024.03.0'>]
2025-03-12 18:18:13.930 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-multicast with version 2024.03.0
2025-03-12 18:18:15.312 INFO (MainThread) [supervisor.plugins.multicast] Starting Multicast plugin
2025-03-12 18:19:53.069 INFO (MainThread) [supervisor.docker.multicast] Starting Multicast ghcr.io/home-assistant/amd64-hassio-multicast with version 2024.03.0 - Host
2025-03-12 18:19:53.070 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
2025-03-12 18:19:53.090 INFO (MainThread) [supervisor.docker.interface] No version found for ghcr.io/home-assistant/generic-x86-64-homeassistant
2025-03-12 18:19:53.090 INFO (MainThread) [supervisor.homeassistant.core] No Home Assistant Docker image ghcr.io/home-assistant/generic-x86-64-homeassistant found.
2025-03-12 18:19:53.097 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/generic-x86-64-homeassistant with version landingpage
2025-03-12 18:19:53.097 INFO (MainThread) [supervisor.homeassistant.core] Using preinstalled landingpage
2025-03-12 18:19:53.123 INFO (MainThread) [supervisor.homeassistant.core] Starting HomeAssistant landingpage
2025-03-12 18:19:55.720 INFO (MainThread) [supervisor.homeassistant.module] Update pulse/client.config: /data/tmp/homeassistant_pulse
2025-03-12 18:22:14.346 INFO (MainThread) [supervisor.docker.homeassistant] Starting Home Assistant ghcr.io/home-assistant/generic-x86-64-homeassistant with version landingpage
2025-03-12 18:22:18.262 INFO (MainThread) [supervisor.os.manager] Detect Home Assistant Operating System 14.2 / BootSlot A
2025-03-12 18:22:18.266 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/music-assistant/home-assistant-addon repository
2025-03-12 18:22:18.266 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/hassio-addons/repository repository
2025-03-12 18:22:18.268 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/home-assistant/addons repository
2025-03-12 18:22:18.270 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/esphome/home-assistant-addon repository
2025-03-12 18:22:30.910 INFO (MainThread) [supervisor.store] Loading add-ons from store: 81 all - 81 new - 0 remove
2025-03-12 18:22:30.924 INFO (MainThread) [supervisor.addons.manager] Found 0 installed add-ons
2025-03-12 18:22:30.935 INFO (MainThread) [supervisor.backups.manager] Found 0 backup files
2025-03-12 18:22:30.935 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
2025-03-12 18:22:30.935 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
2025-03-12 18:22:30.935 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state setup
2025-03-12 18:22:30.936 INFO (MainThread) [supervisor.resolution.checks.base] Run check for detached_addon_missing/addon
2025-03-12 18:22:30.936 INFO (MainThread) [supervisor.resolution.checks.base] Run check for detached_addon_removed/addon
2025-03-12 18:22:30.936 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
2025-03-12 18:22:30.936 INFO (MainThread) [supervisor.resolution.checks.base] Run check for disabled_data_disk/system
2025-03-12 18:22:30.936 INFO (MainThread) [supervisor.resolution.check] System checks complete
2025-03-12 18:22:30.936 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state setup
2025-03-12 18:22:30.936 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2025-03-12 18:22:30.936 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - setup
2025-03-12 18:22:30.936 INFO (MainThread) [__main__] Running Supervisor
2025-03-12 18:22:45.317 INFO (MainThread) [supervisor.os.manager] Rauc: slot A - activated slot kernel.0, marked slot kernel.0 as good
2025-03-12 18:22:45.332 INFO (MainThread) [supervisor.supervisor] Fetching AppArmor profile https://version.home-assistant.io/apparmor_stable.txt
2025-03-12 18:22:45.456 INFO (MainThread) [supervisor.host.apparmor] Adding/updating AppArmor profile: hassio-supervisor
2025-03-12 18:22:46.749 INFO (MainThread) [supervisor.supervisor] Update Supervisor to version 2025.03.2
2025-03-12 18:22:46.750 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/amd64-hassio-supervisor with tag 2025.03.2.
2025-03-12 18:30:06.982 INFO (MainThread) [supervisor.misc.scheduler] Shutting down scheduled tasks
2025-03-12 18:30:06.983 INFO (MainThread) [supervisor.docker.monitor] Stopped docker events monitor
2025-03-12 18:30:16.987 WARNING (MainThread) [supervisor.core] Stage 1: Force Shutdown!
2025-03-12 18:30:23.763 INFO (MainThread) [supervisor.hardware.monitor] Stopped Supervisor hardware monitor
2025-03-12 18:30:23.769 INFO (MainThread) [supervisor.dbus.manager] Closed conection to system D-Bus.
2025-03-12 18:30:25.563 INFO (MainThread) [supervisor.core] Supervisor is down - 0
2025-03-12 18:30:25.565 ERROR (MainThread) [asyncio] Task was destroyed but it is pending!
task: <Task pending name='Task-573' coro=<RestAPI.stop() running at /usr/src/supervisor/supervisor/api/__init__.py:791> wait_for=<_GatheringFuture finished result=[None, None]>>
2025-03-12 18:30:25.567 INFO (MainThread) [__main__] Closing Supervisor
[01:30:32] WARNING: Halt Supervisor
[01:30:36] INFO: Supervisor restart after closing
[01:30:37] INFO: Watchdog restart after closing
s6-rc: info: service s6rc-oneshot-runner successfully stopped
The most concerning thing I see is something about task was destroyed but it is pending, but I don’t really know how to interpret any of this.
net info shows that one adapter is connected, with nameservers 75.75.75.75 and 75.75.75.74
Any help is appreciated
