I have virtualbox running on Ubutu 18.0.4 and I have read through everything article on the internet…lol.
I’ve forwarded USB from my host to my guest but I cannot get home assistant to see it. This is my first time with Hassbian and I’ve been fighting it for a few weeks.
The commands to list USB show the AEOTEC device at /dev/ttyACM0
But HA will not pick it up.
What am I missing? I’ve tried everything I can find to try.
I put my logging in debug mode and I see this. See where it states you can only have one zwave instance. But I have never gotten this configured and it does not show in my integrations.
‘component.mqtt.config.step.broker.data.password’: ‘Password’, ‘component.mqtt.config.step.broker.data.port’: ‘Port’, ‘component.mqtt.config.step.broker.data.username’: ‘Username’, ‘component.mqtt.config.step.broker.description’: ‘Please enter the connection information of your MQTT broker.’, ‘component.mqtt.config.step.broker.title’: ‘MQTT’, ‘component.mqtt.config.step.hassio_confirm.data.discovery’: ‘Enable discovery’, ‘component.mqtt.config.step.hassio_confirm.description’: ‘Do you want to configure Home Assistant to connect to the MQTT broker provided by the hass.io add-on {addon}?’, ‘component.mqtt.config.step.hassio_confirm.title’: ‘MQTT Broker via Hass.io add-on’, ‘component.mqtt.config.title’: ‘MQTT’, ‘component.zwave.config.abort.already_configured’: ‘Z-Wave is already configured’, ‘component.zwave.config.abort.one_instance_only’: ‘Component only supports one Z-Wave instance’, ‘component.zwave.config.error.option_error’: ‘Z-Wave validation failed. Is the path to the USB stick correct?’, ‘component.zwave.config.step.user.data.network_key’: ‘Network Key (leave blank to auto-generate)’, ‘component.zwave.config.step.user.data.usb_path’: ‘USB Path’, ‘component.zwave.config.step.user.description’: ‘See https://www.home-assistant.io/docs/z-wave/installation/ for information on the configuration variables’, ‘component.zwave.config.step.user.title’: ‘Set up Z-Wave’, ‘component.zwave.config.title’: ‘Z-Wave’, ‘component.point.config.abort.already_setup’: ‘You can only configure a Point account.’, ‘component.point.config.abort.authorize_url_fail’: ‘Unknown error generating an authorize url.’, ‘component.point.config.abort.authorize_url_timeout’: ‘Timeout generating authorize url.’, ‘component.point.config.abort.external_setup’: 'Point successfully configured
I figured this out. It’s because my USB dongle was not exposed to the Docker container. I had to start the container including the -device mapping so HASS could see the USB.
