Tried repeatedly to heal node 51 which is an Aeon labs ZW075 mains powered switch, but it keeps failing. The logs seem to indicate it is an issue related to a return route to node 17 which is q qubino flush 2 relay.
Any idea’s how I can fix this, I can heal other nodes OK?
Thanks!
Subscribed to Z-Wave JS Log Messages…
Log Level changed to: Verbose
2023-09-05T22:17:35.663Z DRIVER « [Node 068] [REQ] [ApplicationCommand]
└─[MultilevelSensorCCReport]
type: Air temperature
scale: Celsius
value: 19.3
2023-09-05T22:17:36.174Z DRIVER « [Node 068] [REQ] [ApplicationCommand]
scale: Celsius
value: 19.3
2023-09-05T22:17:36.262Z DRIVER « [Node 068] [REQ] [ApplicationCommand]
scale: Celsius
value: 19.3
2023-09-05T22:17:36.905Z DRIVER « [Node 068] [REQ] [ApplicationCommand]
scale: Celsius
value: 19.3
2023-09-05T22:17:37.032Z DRIVER « [Node 068] [REQ] [ApplicationCommand]
scale: Celsius
value: 19.3
2023-09-05T22:17:37.746Z DRIVER all queues busy
2023-09-05T22:17:37.756Z DRIVER » [REQ] [GetBackgroundRSSI]
2023-09-05T22:17:37.764Z DRIVER « [RES] [GetBackgroundRSSI]
channel 0: No signal detected
channel 1: No signal detected
2023-09-05T22:17:37.788Z DRIVER all queues idle
2023-09-05T22:17:57.166Z DRIVER « [Node 019] [REQ] [ApplicationCommand]
└─[MeterCCReport]
type: Electric
scale: V
rate type: Consumed
value: 242.013
time delta: 0 seconds
2023-09-05T22:17:57.448Z DRIVER « [Node 019] [REQ] [ApplicationCommand]
└─[MeterCCReport]
type: Electric
scale: A
rate type: Consumed
value: 0
2023-09-05T22:17:57.747Z DRIVER « [Node 019] [REQ] [ApplicationCommand]
└─[MeterCCReport]
type: Electric
scale: kWh
rate type: Consumed
value: 429.368
time delta: 60 seconds
prev. value: 429.368
2023-09-05T22:17:57.804Z DRIVER « [Node 051] [REQ] [ApplicationCommand]
└─[MeterCCReport]
type: Electric
scale: kWh
rate type: Consumed
value: 624.271
time delta: 30 seconds
prev. value: 624.271
2023-09-05T22:17:57.894Z DRIVER « [Node 051] [REQ] [ApplicationCommand]
└─[MeterCCReport]
type: Electric
scale: kWh
rate type: Consumed
value: 624.271
2023-09-05T22:17:59.747Z DRIVER « [Node 066] [REQ] [ApplicationCommand]
└─[MeterCCReport]
type: Electric
scale: kWh
rate type: Consumed
value: 310.32
prev. value: 310.319
2023-09-05T22:18:00.125Z DRIVER « [Node 066] [REQ] [ApplicationCommand]
└─[MeterCCReport]
type: Electric
scale: W
rate type: Consumed
value: 37.729
2023-09-05T22:18:00.844Z DRIVER « [Node 072] [REQ] [ApplicationCommand]
└─[MeterCCReport]
type: Electric
scale: V
rate type: Consumed
value: 241.65
2023-09-05T22:18:00.933Z DRIVER « [Node 072] [REQ] [ApplicationCommand]
└─[MeterCCReport]
type: Electric
scale: A
rate type: Consumed
value: 0.055
2023-09-05T22:18:01.033Z DRIVER « [Node 072] [REQ] [ApplicationCommand]
└─[MeterCCReport]
type: Electric
scale: kWh
rate type: Consumed
value: 181.138
prev. value: 181.138
2023-09-05T22:18:07.740Z DRIVER all queues busy
2023-09-05T22:18:07.751Z DRIVER » [REQ] [GetBackgroundRSSI]
2023-09-05T22:18:07.759Z DRIVER « [RES] [GetBackgroundRSSI]
channel 0: -94 dBm
2023-09-05T22:18:07.765Z DRIVER all queues idle
2023-09-05T22:18:17.712Z DRIVER « [Node 017] [REQ] [ApplicationCommand]
└─[MultiChannelCCCommandEncapsulation]
│ source: 1
│ destination: 0
└─[MeterCCReport]
type: Electric
scale: W
rate type: Consumed
value: 0
2023-09-05T22:18:18.702Z DRIVER « [Node 017] [REQ] [ApplicationCommand]
│ source: 2
│ destination: 0
└─[MeterCCReport]
type: Electric
scale: W
rate type: Consumed
value: 0
2023-09-05T22:18:27.783Z DRIVER « [Node 051] [REQ] [ApplicationCommand]
└─[MeterCCReport]
type: Electric
scale: kWh
rate type: Consumed
value: 624.271
2023-09-05T22:18:33.913Z DRIVER « [Node 075] [REQ] [ApplicationCommand]
└─[MeterCCReport]
type: Electric
scale: kWh
rate type: Consumed
value: 20.921
prev. value: 20.921
2023-09-05T22:18:34.163Z DRIVER « [Node 035] [REQ] [ApplicationCommand]
└─[MeterCCReport]
type: Electric
scale: V
rate type: Consumed
value: 242.242
2023-09-05T22:18:34.358Z DRIVER « [Node 035] [REQ] [ApplicationCommand]
└─[MeterCCReport]
type: Electric
scale: A
rate type: Consumed
value: 0
2023-09-05T22:18:34.557Z DRIVER « [Node 035] [REQ] [ApplicationCommand]
└─[MeterCCReport]
type: Electric
scale: kWh
rate type: Consumed
value: 495.032
time delta: 61 seconds
prev. value: 495.032
2023-09-05T22:18:35.939Z DRIVER « [Node 007] [REQ] [ApplicationCommand]
└─[MultilevelSwitchCCReport]
current value: 0
2023-09-05T22:18:37.741Z DRIVER all queues busy
2023-09-05T22:18:37.751Z DRIVER » [REQ] [GetBackgroundRSSI]
2023-09-05T22:18:37.761Z DRIVER « [RES] [GetBackgroundRSSI]
2023-09-05T22:18:37.765Z DRIVER all queues idle
2023-09-05T22:18:53.218Z CNTRLR [Node 051] Healing node...
2023-09-05T22:18:53.224Z CNTRLR » [Node 051] refreshing neighbor list (attempt 1)...
2023-09-05T22:18:53.256Z DRIVER all queues busy
2023-09-05T22:18:53.275Z DRIVER » [Node 051] [REQ] [RequestNodeNeighborUpdate]
callback id: 17
2023-09-05T22:18:53.414Z DRIVER « [REQ] [RequestNodeNeighborUpdate]
callback id: 17
update status: UpdateStarted
2023-09-05T22:18:54.508Z DRIVER « [REQ] [RequestNodeNeighborUpdate]
callback id: 17
2023-09-05T22:19:00.789Z DRIVER « [Node 019] [REQ] [ApplicationCommand]
└─[MeterCCReport]
type: Electric
scale: V
rate type: Consumed
value: 242.822
2023-09-05T22:19:00.837Z DRIVER « [Node 072] [REQ] [ApplicationCommand]
└─[MeterCCReport]
type: Electric
scale: V
rate type: Consumed
value: 242.493
2023-09-05T22:19:00.882Z DRIVER « [Node 072] [REQ] [ApplicationCommand]
└─[MeterCCReport]
type: Electric
scale: V
rate type: Consumed
value: 242.493
2023-09-05T22:19:00.936Z DRIVER « [Node 072] [REQ] [ApplicationCommand]
└─[MeterCCReport]
type: Electric
scale: A
rate type: Consumed
value: 0.055
2023-09-05T22:19:01.048Z DRIVER « [Node 072] [REQ] [ApplicationCommand]
└─[MeterCCReport]
type: Electric
scale: A
rate type: Consumed
value: 0.055
2023-09-05T22:19:01.130Z DRIVER « [Node 072] [REQ] [ApplicationCommand]
└─[MeterCCReport]
type: Electric
scale: A
rate type: Consumed
value: 0.055
2023-09-05T22:19:01.237Z DRIVER « [Node 019] [REQ] [ApplicationCommand]
└─[MeterCCReport]
type: Electric
scale: V
rate type: Consumed
value: 242.822
2023-09-05T22:19:02.438Z DRIVER « [Node 072] [REQ] [ApplicationCommand]
└─[MeterCCReport]
type: Electric
scale: A
rate type: Consumed
value: 0.055
2023-09-05T22:19:02.828Z DRIVER « [Node 072] [REQ] [ApplicationCommand]
└─[MeterCCReport]
type: Electric
scale: A
rate type: Consumed
value: 0.055
2023-09-05T22:19:02.986Z DRIVER « [Node 072] [REQ] [ApplicationCommand]
└─[MeterCCReport]
type: Electric
scale: A
rate type: Consumed
value: 0.055
2023-09-05T22:19:03.025Z DRIVER « [Node 072] [REQ] [ApplicationCommand]
└─[MeterCCReport]
type: Electric
scale: A
rate type: Consumed
value: 0.055
2023-09-05T22:19:03.104Z DRIVER « [Node 072] [REQ] [ApplicationCommand]
└─[MeterCCReport]
type: Electric
scale: A
rate type: Consumed
value: 0.055
2023-09-05T22:19:03.224Z DRIVER « [Node 072] [REQ] [ApplicationCommand]
└─[MeterCCReport]
type: Electric
scale: kWh
rate type: Consumed
value: 181.138
time delta: 62 seconds
2023-09-05T22:19:04.538Z DRIVER « [Node 066] [REQ] [ApplicationCommand]
└─[MeterCCReport]
type: Electric
scale: kWh
rate type: Consumed
value: 310.32
prev. value: 310.32
2023-09-05T22:19:06.531Z DRIVER « [Node 019] [REQ] [ApplicationCommand]
└─[MeterCCReport]
type: Electric
scale: A
rate type: Consumed
value: 0
2023-09-05T22:19:06.724Z DRIVER « [Node 066] [REQ] [ApplicationCommand]
└─[MeterCCReport]
type: Electric
scale: kWh
rate type: Consumed
value: 310.32
prev. value: 310.32
2023-09-05T22:19:07.577Z DRIVER « [Node 051] [REQ] [ApplicationCommand]
└─[MeterCCReport]
type: Electric
scale: kWh
rate type: Consumed
value: 624.271
2023-09-05T22:19:08.021Z DRIVER « [Node 019] [REQ] [ApplicationCommand]
└─[MeterCCReport]
type: Electric
scale: kWh
rate type: Consumed
value: 429.368
time delta: 70 seconds
2023-09-05T22:19:08.325Z DRIVER « [Node 019] [REQ] [ApplicationCommand]
└─[MeterCCReport]
type: Electric
scale: kWh
rate type: Consumed
value: 429.368
2023-09-05T22:19:11.660Z DRIVER « [REQ] [RequestNodeNeighborUpdate]
callback id: 17
update status: UpdateDone
2023-09-05T22:19:11.668Z CNTRLR « [Node 051] neighbor list refreshed...
2023-09-05T22:19:11.670Z CNTRLR » [Node 051] deleting return routes (attempt 1)...
2023-09-05T22:19:11.672Z CNTRLR » [Node 051] Deleting all return routes...
2023-09-05T22:19:11.685Z DRIVER » [Node 051] [REQ] [DeleteReturnRoute]
payload: 0x3312
2023-09-05T22:19:11.693Z DRIVER « [RES] [DeleteReturnRoute]
has started: true
2023-09-05T22:19:12.290Z DRIVER « [REQ] [DeleteReturnRoute]
callback id: 18
transmit status: OK
2023-09-05T22:19:12.311Z CNTRLR » [Node 051] assigning return routes to the following nodes:
1, 118, 17, 51, 9
2023-09-05T22:19:12.312Z CNTRLR » [Node 051] assigning return route to node 1 (attempt 1)...
2023-09-05T22:19:12.315Z CNTRLR » [Node 051] Assigning SUC return route...
2023-09-05T22:19:12.317Z CNTRLR » [Node 051] Deleting SUC return route...
2023-09-05T22:19:12.324Z DRIVER » [Node 051] [REQ] [DeleteSUCReturnRoute]
payload: 0x3313
2023-09-05T22:19:12.337Z DRIVER « [RES] [DeleteSUCReturnRoute]
was executed: true
2023-09-05T22:19:12.601Z DRIVER « [REQ] [DeleteSUCReturnRoute]
callback id: 19
transmit status: OK
2023-09-05T22:19:12.617Z DRIVER » [Node 051] [REQ] [AssignSUCReturnRoute]
payload: 0x3314
2023-09-05T22:19:12.631Z DRIVER « [RES] [AssignSUCReturnRoute]
was executed: true
2023-09-05T22:19:13.688Z DRIVER « [REQ] [AssignSUCReturnRoute]
callback id: 20
transmit status: OK
2023-09-05T22:19:13.697Z CNTRLR » [Node 051] assigning return route to node 118 (attempt 1)...
2023-09-05T22:19:13.698Z CNTRLR » [Node 051] Assigning return routes to node 118...
2023-09-05T22:19:13.706Z DRIVER » [Node 051] [REQ] [AssignReturnRoute]
payload: 0x337615
2023-09-05T22:19:13.717Z DRIVER « [RES] [AssignReturnRoute]
has started: true
2023-09-05T22:19:14.048Z DRIVER « [REQ] [AssignReturnRoute]
callback id: 21
transmit status: OK
2023-09-05T22:19:14.056Z CNTRLR » [Node 051] assigning return route to node 17 (attempt 1)...
2023-09-05T22:19:14.058Z CNTRLR » [Node 051] Assigning return routes to node 17...
2023-09-05T22:19:14.065Z DRIVER » [Node 051] [REQ] [AssignReturnRoute]
payload: 0x331116
2023-09-05T22:19:16.254Z DRIVER « [RES] [AssignReturnRoute]
has started: true
2023-09-05T22:19:16.261Z DRIVER « [REQ] [AssignReturnRoute]
callback id: 22
transmit status: NoRoute
2023-09-05T22:19:16.267Z CNTRLR [Node 051] Route resolution failed
2023-09-05T22:19:16.270Z CNTRLR » [Node 051] assigning return route to node 17 (attempt 2)...
2023-09-05T22:19:16.272Z CNTRLR » [Node 051] Assigning return routes to node 17...
2023-09-05T22:19:16.279Z DRIVER » [Node 051] [REQ] [AssignReturnRoute]
payload: 0x331117
2023-09-05T22:19:18.467Z DRIVER « [RES] [AssignReturnRoute]
has started: true
2023-09-05T22:19:18.474Z DRIVER « [REQ] [AssignReturnRoute]
callback id: 23
2023-09-05T22:19:18.480Z CNTRLR [Node 051] Route resolution failed
2023-09-05T22:19:18.481Z CNTRLR » [Node 051] assigning return route to node 17 (attempt 3)...
2023-09-05T22:19:18.483Z CNTRLR » [Node 051] Assigning return routes to node 17...
2023-09-05T22:19:18.494Z DRIVER » [Node 051] [REQ] [AssignReturnRoute]
payload: 0x331118
2023-09-05T22:19:20.684Z DRIVER « [RES] [AssignReturnRoute]
has started: true
2023-09-05T22:19:20.693Z DRIVER « [REQ] [AssignReturnRoute]
callback id: 24
2023-09-05T22:19:20.701Z CNTRLR [Node 051] Route resolution failed
2023-09-05T22:19:20.702Z CNTRLR » [Node 051] assigning return route to node 17 (attempt 4)...
2023-09-05T22:19:20.704Z CNTRLR » [Node 051] Assigning return routes to node 17...
2023-09-05T22:19:20.711Z DRIVER » [Node 051] [REQ] [AssignReturnRoute]
payload: 0x331119
2023-09-05T22:19:22.901Z DRIVER « [RES] [AssignReturnRoute]
has started: true
2023-09-05T22:19:22.913Z DRIVER « [REQ] [AssignReturnRoute]
callback id: 25
2023-09-05T22:19:22.919Z CNTRLR [Node 051] Route resolution failed
2023-09-05T22:19:22.921Z CNTRLR » [Node 051] assigning return route to node 17 (attempt 5)...
2023-09-05T22:19:22.922Z CNTRLR » [Node 051] Assigning return routes to node 17...
2023-09-05T22:19:22.930Z DRIVER » [Node 051] [REQ] [AssignReturnRoute]
payload: 0x33111a
2023-09-05T22:19:25.124Z DRIVER « [RES] [AssignReturnRoute]
has started: true
2023-09-05T22:19:25.134Z DRIVER « [REQ] [AssignReturnRoute]
callback id: 26
2023-09-05T22:19:25.139Z CNTRLR [Node 051] Route resolution failed
2023-09-05T22:19:25.141Z CNTRLR [Node 051] failed to assign return route after 5 attempts, healing failed
2023-09-05T22:19:25.145Z DRIVER all queues idle
2023-09-05T22:19:25.164Z DRIVER « [Node 017] [REQ] [ApplicationCommand]
│ source: 1
│ destination: 0
└─[MeterCCReport]
type: Electric
scale: W
rate type: Consumed
value: 0
2023-09-05T22:19:25.240Z DRIVER « [Node 017] [REQ] [ApplicationCommand]
│ source: 1
│ destination: 0
└─[MeterCCReport]
type: Electric
scale: W
rate type: Consumed
value: 0
2023-09-05T22:19:25.492Z DRIVER « [Node 017] [REQ] [ApplicationCommand]
│ source: 1
│ destination: 0
└─[MeterCCReport]
type: Electric
scale: W
rate type: Consumed
value: 0
2023-09-05T22:19:25.994Z DRIVER « [Node 017] [REQ] [ApplicationCommand]
│ source: 2
│ destination: 0
└─[MeterCCReport]
type: Electric
scale: W
rate type: Consumed
value: 0
2023-09-05T22:19:27.803Z DRIVER « [Node 051] [REQ] [ApplicationCommand]
└─[MeterCCReport]
type: Electric
scale: kWh
rate type: Consumed
value: 624.272
2023-09-05T22:19:30.153Z DRIVER all queues busy
2023-09-05T22:19:30.161Z DRIVER » [REQ] [GetBackgroundRSSI]
2023-09-05T22:19:30.170Z DRIVER « [RES] [GetBackgroundRSSI]
2023-09-05T22:19:30.178Z DRIVER all queues idle
