I’m trying to somehow imitate the status led in a node, particularly when HA is down/off OR when wifi is off. The node’s led indeed starts blinking when no wifi is connected. But not when HA is down, for example when rebooting the host. Another node that I have with the status led enabled starts blinking as soon as I reboot the host. Is the below syntax correct? Particularly the not/or syntax.
interval:
- interval: 2000ms
then:
- if:
condition:
not:
or:
- wifi.connected:
- api.connected:
then:
- light.turn_on:
flash_length: 160ms
brightness: 100%
- switch.turn_off:
- if:
condition:
and:
- wifi.connected:
- api.connected:
- switch.is_on: relay
- switch.is_off: led
then:
- switch.turn_on:
Edit: Found it, I feel soooo noob, should be:
- if:
condition:
or:
not:
- wifi.connected:
- api.connected:
