Last saturday I moved from supervised to HA-OS 11.4 in a Proxmox VM. Everything worked fine so far, I even installed a couple of updates (for integrations, that is).
Whenever I try to install HA Core Update 2024.1.5, it starts installing, but after around 30 seconds the VM gets shut down. When I start it manually, 2024.1.4 is still active.
I can see no errors in the log file (they start at boot time)
What should I do? Where do I get better logs?
