I tried to integrate the ikea gateway (Ver 1.10.30) via the configuration.yaml, but when i test the config it tries and fail to install pytradfri with this error:
‘Testing configuration at /home/matteo/.homeassistant
INFO:homeassistant.util.package:Attempting install of pytradfri[async]==6.4.0
ERROR:homeassistant.util.package:Unable to install package pytradfri[async]==6.4.0: Command "/usr/bin/python3 -u -c "import setuptools, tokenize;file=’/tmp/pip-build-uqej96d2/DTLSSocket/setup.py’;f=getattr(tokenize, ‘open’, open)(file);code=f.read().replace(’\r\n’, ‘\n’);f.close();exec(compile(code, file, ‘exec’))" install --record /tmp/pip-elwccf9a-record/install-record.txt --single-version-externally-managed --prefix --compile --user --prefix=" failed with error code 1 in /tmp/pip-build-uqej96d2/DTLSSocket/
Failed config
General Errors:
- Component error: tradfri - Requirements for tradfri not found: [‘pytradfri[async]==6.4.0’].’
Anyone can help?
