Cannot login via keys with Visual Code
until recently, I was able to access and edit my HA config with visual code via SSH.
Since the update from the AddOn Terminal&SSH to version 9.6.0 it no longer works.
Then I found out that the KEY files need to be renewed.
Now I can log in again with Putty and Key Files, but not with Visual Code with the AddOn SSHFS.
Then comes an error that the format of the key is wrong.
If I log in with a password, then it works.
Does anyone have an idea how to get visual code working again with the SSHFS addon?
Thanks and regards
Herbert
