Cannot re-include dead Zwave node after migration
Yesterday I migrated my Raspberry PI 4 installation of Home Assistant OS to a Intel NUC running raspberri PI OS in a Proxmox VM.
Everything went butter smooth and I was up and running within an hour.
However since this migration I have an issue with one of my Zwave nodes. This particular node was reported dead by home assistant.
The node is a " ECO-DIM.07 Led dimmer"
I am using the Zwave-JS supervisor add-on to control my network.
Zwave controller I use is the Aeotec Z-Stick gen 5.
Since there is no option to remove dead nodes from the controller in Zwave-JS I did some googeling and found I need to install ZwaveJsToMqtt addon. Installed this and struggled a bit, but in the end I was able to remove the dead node from the controller. Also the device disappeared from the device list in Home Assistant. So I assume the dead node is removed succesfully and both unknown to Home Assistant and my Zwave stick.
Next I reinstalled/re-enabled the Zwave-JS addon and try including the node again.
Did many attempts both including and excluding the node, but there is no response at all from Home Assistant.
Only thing in the addon log is:
2021-04-11T06:44:50.569Z CNTRLR   stopping inclusion process...
2021-04-11T06:44:50.672Z CNTRLR   handling add node request (status = Done)
2021-04-11T06:44:50.673Z CNTRLR   done called for 0
2021-04-11T06:44:50.673Z CNTRLR   the inclusion process was stopped
Not sure how to proceed or where I can find some detailed Zwave logs to see what is the culprit.
