Cannot reach HA from internal network when added certificate
I have added ssl certificate for the HA
i can access now only from HTTPs interface and cannot reach from the internal network,
can it be solved?
The whole point of adding a certificate is that you can’t access HA in non secure ways.
You can however try this: htts://ipaddress:8123 which will give you a warning that you can bypass
no warning just cannot reach message …
i understand the idea but if i am inside the network i see no reason to use the certificate…
It’s not about seeing the reason, if you set up ha to use ssl, that’s the only way you can access it
