I’m running HA Core 2025.1.3 on raspberry pi4 and I observed that I’m not able to create/save scripts from the UI. Whenever I save the a script I get a 500 Response in the UI and the following log:
Logger: aiohttp.server
Source: /usr/local/lib/python3.13/site-packages/aiohttp/web_protocol.py:451
First occurred: 14:12:17 (5 occurrences)
Last logged: 14:13:18
Error handling request
File "/usr/local/lib/python3.13/site-packages/aiohttp/web_protocol.py", line 480, in _handle_request
resp = await request_handler(request)
File "/usr/local/lib/python3.13/site-packages/aiohttp/web_app.py", line 569, in _handle
return await handler(request)
File "/usr/local/lib/python3.13/site-packages/aiohttp/web_middlewares.py", line 117, in impl
File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 92, in security_filter_middleware
File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 83, in forwarded_middleware
File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 26, in request_context_middleware
File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 86, in ban_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 242, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/headers.py", line 32, in headers_middleware
response = await handler(request)
File "/usr/src/homeassistant/homeassistant/helpers/http.py", line 73, in handle
result = await handler(request, **request.match_info)
File "/usr/src/homeassistant/homeassistant/components/http/decorators.py", line 81, in with_admin
return await func(self, request, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/components/config/view.py", line 92, in get
current = await self.read_config(hass)
File "/usr/src/homeassistant/homeassistant/components/config/view.py", line 165, in read_config
current = await hass.async_add_executor_job(_read, hass.config.path(self.path))
File "/usr/local/lib/python3.13/concurrent/futures/thread.py", line 59, in run
File "/usr/src/homeassistant/homeassistant/components/config/view.py", line 243, in _read
return load_yaml(path)
File "/usr/src/homeassistant/homeassistant/util/yaml/loader.py", line 168, in load_yaml
return parse_yaml(conf_file, secrets)
File "/usr/src/homeassistant/homeassistant/util/yaml/loader.py", line 201, in parse_yaml
return _parse_yaml(FastSafeLoader, content, secrets)
File "/usr/src/homeassistant/homeassistant/util/yaml/loader.py", line 228, in _parse_yaml
return yaml.load(content, Loader=lambda stream: loader(stream, secrets)) # type: ignore[arg-type]
File "/usr/local/lib/python3.13/site-packages/yaml/__init__.py", line 81, in load
return loader.get_single_data()
File "/usr/local/lib/python3.13/site-packages/yaml/constructor.py", line 51, in get_single_data
return self.construct_document(node)
File "/usr/local/lib/python3.13/site-packages/yaml/constructor.py", line 55, in construct_document
data = self.construct_object(node)
File "/usr/local/lib/python3.13/site-packages/yaml/constructor.py", line 100, in construct_object
data = constructor(self, node)
File "/usr/src/homeassistant/homeassistant/util/yaml/loader.py", line 413, in _handle_mapping_tag
nodes = loader.construct_pairs(node)
File "/usr/local/lib/python3.13/site-packages/yaml/constructor.py", line 155, in construct_pairs
value = self.construct_object(value_node, deep=deep)
File "/usr/src/homeassistant/homeassistant/util/yaml/loader.py", line 451, in _construct_seq
(obj,) = loader.construct_yaml_seq(node)
File "/usr/local/lib/python3.13/site-packages/yaml/constructor.py", line 408, in construct_yaml_seq
data.extend(self.construct_sequence(node))
File "/usr/local/lib/python3.13/site-packages/yaml/constructor.py", line 129, in construct_sequence
return [self.construct_object(child, deep=deep)
File "/usr/src/homeassistant/homeassistant/util/yaml/loader.py", line 481, in secret_yaml
raise HomeAssistantError("Secrets not supported in this YAML file")
homeassistant.exceptions.HomeAssistantError: Secrets not supported in this YAML file
I’m still able to add new and modify existing scripts from the yaml file.
I also get the banner “This script cannot be edited from the UI, because it is not stored in the ‘scripts.yaml’ file.” when I open any script in the UI. When I click MIGRATE and the SAVE, again I get the 500 Error Response.
How can I get back to the behavior that I was able to modify scripts both from the UI and the yaml?
