I did a mistake to write my problem in german.
So I repeat my question now in english.
I did a automation with an aqara vibration sensor . The sensor works and fires. as an action I’ll be informed via mobil and with an email.
Via mobil it works. Via email it doesn’t work.
So here ist my Yaml:
Example Email configuration
notify:
platform: smtp
server: “smtp.ionos.de”
sender: “email of the sender”
sender_name: “type in any name ”
recipient: “email-adress of the receiver”
encryption: tls
port: 587
timeout: 15
username: “users email adress”
password: “password”
debug: true
in the automations.yaml I did the following code:
alias: OH104 heat pump is moved
description: ‘’
triggers:
I got an error message:
The Automation „OH104 heat pump was moved“ (automation.oh104_heat pump was moved) has an unkown action: notify.oh104emailalarm.
The first action works fine, the second action got the above error message.
First, check in the Actions tool to make sure that notify.oh104emailalarm shows up as an available action. If it doesn’t, restart Home Assistant, and check again.
If notify.oh104emailalarm is available as an action, make sure to include a message in your action (as suggested on your previous post). The message configuration variable is required.
Now I get an other error:
OH104 Wärmepumpe wird bewegt: Error executing script. Service not found for call_service at pos 2: Action notify.oh104emailalarm not found
2025-08-17 15:26:31.166 ERROR (MainThread) [homeassistant.components.notify] Error setting up platform smtp
File “/usr/src/homeassistant/homeassistant/components/smtp/notify.py”, line 108, in get_service
File “/usr/src/homeassistant/homeassistant/components/smtp/notify.py”, line 172, in connection_is_valid
File “/usr/src/homeassistant/homeassistant/components/smtp/notify.py”, line 151, in connect
mail = smtplib.SMTP_SSL(
File “/usr/local/lib/python3.13/smtplib.py”, line 1022, in init
SMTP.init(self, host, port, local_hostname, timeout,
File “/usr/local/lib/python3.13/smtplib.py”, line 255, in init
File “/usr/local/lib/python3.13/smtplib.py”, line 341, in connect
File “/usr/local/lib/python3.13/smtplib.py”, line 1029, in _get_socket
Good question. Worked for years with the smtp server of my ISP, about a year ago it stopped working for unknown reason. Now I use the gmail integration.
