Hi all. Apologies, but I’m just not able to find anyone else with this issue. I installed according to the “virtualenv” tutorial but after installation I cannot get home assistant to run. hass --open-ui fails with the following messages:
homeassistant@raspberrypi:/srv/homeassistant/bin$ ./hass --open-ui
File “./hass”, line 11, in
sys.exit(main())
File “/srv/homeassistant/lib/python3.4/site-packages/homeassistant/main.py”, line 364, in main
args = get_arguments()
File “/srv/homeassistant/lib/python3.4/site-packages/homeassistant/main.py”, line 121, in get_arguments
import homeassistant.config as config_util
File “/srv/homeassistant/lib/python3.4/site-packages/homeassistant/config.py”, line 21, in
import homeassistant.helpers.config_validation as cv
File “/srv/homeassistant/lib/python3.4/site-packages/homeassistant/helpers/config_validation.py”, line 23, in
from homeassistant.helpers import template as template_helper
File “/srv/homeassistant/lib/python3.4/site-packages/homeassistant/helpers/template.py”, line 7, in
import jinja2
File “/srv/homeassistant/lib/python3.4/site-packages/jinja2/init.py”, line 33, in
from jinja2.environment import Environment, Template
File “/srv/homeassistant/lib/python3.4/site-packages/jinja2/environment.py”, line 15, in
from jinja2 import nodes
File “/srv/homeassistant/lib/python3.4/site-packages/jinja2/nodes.py”, line 19, in
from jinja2.utils import Markup
File “/srv/homeassistant/lib/python3.4/site-packages/jinja2/utils.py”, line 624, in
from markupsafe import Markup, escape, soft_unicode
ImportError: No module named ‘markupsafe’
What I’m getting form this is that i am missing a module… but when I try and (re)install I get this message:
Requirement already up-to-date: MarkupSafe in /usr/lib/python3/dist-packages
Clearly the problem is elsewhere? (Probably behind the keyboard, lol!)
Has anyone any suggestions as to what I’m doing wrong? I’m using raspian on a raspberry pi and am also running pihole - does anyone know if they conflict?
Thanks for any help you can give!
Tommakesmusic
