Cannot update or install addons
TLDR: Cannot update the install or install any addons. Keeps saying no internet (host_internet: false).
I can ping and use curl to get the online.txt from the homeassistant pod, but the hassio_supervisor pod gets connection reset by peer. I can ping 1.1.1.1 from both. Any suggestions? I tried doing this on Virtual Box using the OVA as well.
My Setup:
Raspbery Pi 3B+ - 32gb SD Card
Home Assistant 2023.3.3
Supervisor 2023.03.1
Operating System 9.5
Frontend 20230309.0 - latest
Cat 5e cable hooked up directly to the router.
Networking Settings:
IP Set to Static both in Router & HA GUI
DNS set to 8.8.8.8 (tried 1.1.1.1 and my router as well)
This is a fresh install. I had originally installed this last weekend, but was running into the same error message. Was able to setup everything, and even connect Blink & Amazon to it. Going to add-on’s and trying to install or even update HA, gives the no host internet.
When I powered the device on, it even told me that there was an update but was not able to perform it, that is why I did a fresh install today.
Logs:
Failed to to call /addons/core_ssh/install - 'AddonManager.install' blocked from execution, no host internet connection
7:53:47 PM – (ERROR) Home Assistant Supervisor - message first occurred at 7:36:49 PM and shows up 4 times
Error handling request
7:48:43 PM – (ERROR) /usr/local/lib/python3.10/site-packages/aiohttp/web_protocol.py
2023-03-12 19:36:49.610 ERROR (MainThread) [homeassistant.components.hassio] Failed to to call /addons/core_ssh/install - 'AddonManager.install' blocked from execution, no host internet connection
2023-03-12 19:36:52.988 ERROR (MainThread) [homeassistant.components.hassio] Failed to to call /addons/core_ssh/install - 'AddonManager.install' blocked from execution, no host internet connection
2023-03-12 19:43:49.111 ERROR (MainThread) [homeassistant.components.hassio] Failed to to call /addons/core_ssh/install - 'AddonManager.install' blocked from execution, no host internet connection
2023-03-12 19:48:43.506 ERROR (MainThread) [aiohttp.server] Error handling request
File "/usr/local/lib/python3.10/site-packages/aiohttp/web_protocol.py", line 332, in data_received
messages, upgraded, tail = self._request_parser.feed_data(data)
File "aiohttp/_http_parser.pyx", line 551, in aiohttp._http_parser.HttpParser.feed_data
aiohttp.http_exceptions.BadStatusLine: 400, message="Bad status line 'Invalid method encountered'"
2023-03-12 19:53:47.852 ERROR (MainThread) [homeassistant.components.hassio] Failed to to call /addons/core_ada/install - 'AddonManager.install' blocked from execution, no host internet connection
The things I have tried:
1) Swapped the ethernet cable out
2) Changing DNS
3) Assigning a static IP
4) Rebooting
5) Reinstall
I am at a loss, am I missing something?
Appreciate any help!
EDIT:
Looked in router and I see outgoing connections from the raspberry pi to the internet.
Access time	MAC Address / Client Name	Domain name
2023-3-12  20:30:11	raspberrypi	cas.codenotary.com
2023-3-12  20:30:06	raspberrypi	account-link.nabucasa.com
2023-3-12  20:30:03	raspberrypi	alerts.home-assistant.io
2023-3-12  20:29:59	raspberrypi	nl1.api.radio-browser.info
2023-3-12  20:29:55	raspberrypi	aa015h6buqvih86i1.api.met.no
2023-3-12  20:29:45	raspberrypi	version.home-assistant.io
2023-3-12  20:29:45	raspberrypi	github.com
2023-3-12  20:28:43	raspberrypi	checkonline.home-assistant.io
2023-3-12  20:26:16	raspberrypi	de1.api.radio-browser.info
2023-3-12  20:22:26	raspberrypi	at1.api.radio-browser.info
2023-3-12  19:01:28	raspberrypi	services.home-assistant.io
2023-3-12  18:41:06	raspberrypi	ghcr.io
2023-3-12  18:41:06	raspberrypi	pkg-containers.githubusercontent.com
2023-3-12  18:11:19	raspberrypi	rest-u035.immedia-semi.com
2023-3-07  23:33:34	raspberrypi	acme-v02.api.letsencrypt.org
2023-3-07  23:33:34	raspberrypi	cognito-idp.us-east-1.amazonaws.com
2023-3-07  23:33:34	raspberrypi	cloud.nabucasa.com
2023-3-07  23:26:13	raspberrypi	smartapi.vesync.com
2023-3-07  21:34:46	raspberrypi	rest-prod.immedia-semi.com
Bump.
If I disable the check for host_internet, I can download addons. However, this is not recommended.
Added info & tldr.
hassio_supervisor pod; unable to use curl to online.txt; get connection reset by peer.
Same problem I had. Thanks for sharing this, it helped to search the way, how can I disable it:)
Finaly I have found, so let me share it here. It may helps to someone else too:
I managed to disable the host_internet check: ignoring the internet_host condition.
ha jobs options --ignore-conditions internet_host
The network info still the same, but I was able to install all addons I have:
➜  ~ ha network info | grep internet
supervisor_internet: true
and to reset it back to normal, after addon update completed:
ha jobs reset
Hi Team,
Let me start in saying I am very green to HA and have been avoiding it for some time and just running with Tuya due to the fact that I didnt want to step into a unholy war of code error but I took the leap and crap straight in the head things dont work like above.
I can integrate my Tuya devices, generic cameras, other household devices no problems but the moment I try to update HA I get " Failed to call service update / install. Error updating home assistant core unknown error see Supervisor" ,
when I try any addon I get “Failed to install add-on Unkown error, see supervisor”
HA version is 2022.8.7
Supervisor is 2023.04.01
Frontend is 20220802.0
Any help would be so much appreciated I would like to move forward with HA but at the moment I cant do anything and even trying to update via Docker returns Supervisor errors
PC - Running Ubuntu 18.04.6 LTS
16 gig ram
Intel i5 2.5GHz x4
64bit
HA Core Logs
Failed to to call /addons/core_configurator/install - Unknown error, see supervisor
09:26:03 – (ERROR) Home Assistant Supervisor - message first occurred at 09:22:45 and shows up 2 times
[139823413222352] Error updating Grafana: Unknown error, see supervisor
09:25:53 – (ERROR) Home Assistant WebSocket API - message first occurred at 09:24:11 and shows up 2 times
[139823413222352] Error updating Home Assistant Core Unknown error, see supervisor
09:22:14 – (ERROR) Home Assistant WebSocket API - message first occurred at 08:59:17 and shows up 11 times
[Bedroom speaker(912872af-aba2-422a-047e-78da68814743.local.):8009] Failed to connect to service ServiceInfo(type=‘mdns’, data='Google-Home-Mini-
912872afaba2422a047e78da68814743._googlecast._tcp.local.’), retrying in 5.0s
08:53:06 – (ERROR) /usr/local/lib/python3.10/site-packages/pychromecast/socket_client.py - message first occurred at 08:53:06 and shows up 4 times
Config entry ‘Controller RGB 62C56F’ for flux_led integration not ready yet: [Errno 113] Connect call failed (‘192.168.68.174’, 5577); Retrying in background
08:52:33 – (WARNING) config_entries.py - message first occurred at 08:52:29 and shows up 2 times
Setup of media_player platform dlna_dmr is taking over 10 seconds.
08:52:29 – (WARNING) Media Player - message first occurred at 08:52:29 and shows up 2 times
Supervisor Log
23-05-20 08:52:03 INFO (MainThread) [supervisor.resolution.check] System checks complete
23-05-20 08:52:03 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.SETUP
23-05-20 08:52:03 WARNING (MainThread) [supervisor.resolution.evaluations.base] Detected unsupported OS: Ubuntu 18.04.6 LTS (more-info: https://www.home-assistant.io/more-info/unsupported/os)
23-05-20 08:52:03 WARNING (MainThread) [supervisor.resolution.evaluations.base] NetworkManager is not correctly configured (more-info: https://www.home-assistant.io/more-info/unsupported/network_manager)
23-05-20 08:52:03 WARNING (MainThread) [supervisor.resolution.evaluations.base] Systemd journal is not working correctly or inaccessible (more-info: https://www.home-assistant.io/more-info/unsupported/systemd_journal)
23-05-20 08:52:03 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-05-20 08:52:03 INFO (SyncWorker_0) [supervisor.docker.interface] Cleaning addon_a0d7b954_grafana application
23-05-20 08:52:03 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - CoreState.SETUP
23-05-20 08:52:03 INFO (MainThread) [__main__] Running Supervisor
23-05-20 08:52:03 WARNING (MainThread) [supervisor.core] System running in a unsupported environment!
23-05-20 08:52:03 INFO (MainThread) [supervisor.jobs] 'OSManager.mark_healthy' blocked from execution, no Home Assistant OS available
23-05-20 08:52:03 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.INITIALIZE' starting 0 add-ons
23-05-20 08:52:03 INFO (MainThread) [supervisor.core] Supervisor reboot detected
23-05-20 08:52:03 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
23-05-20 08:52:03 INFO (MainThread) [supervisor.core] Supervisor is up and running
23-05-20 08:52:03 INFO (MainThread) [supervisor.host.info] Updating local host information
23-05-20 08:52:03 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.RUNNING
23-05-20 08:52:03 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.FREE_SPACE/ContextType.SYSTEM
23-05-20 08:52:03 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.IPV4_CONNECTION_PROBLEM/ContextType.SYSTEM
23-05-20 08:52:03 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.PWNED/ContextType.ADDON
23-05-20 08:52:03 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.SECURITY/ContextType.CORE
23-05-20 08:52:03 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.NO_CURRENT_BACKUP/ContextType.SYSTEM
23-05-20 08:52:03 INFO (MainThread) [supervisor.resolution.module] Create new suggestion SuggestionType.CREATE_FULL_BACKUP - ContextType.SYSTEM / None
23-05-20 08:52:03 INFO (MainThread) [supervisor.resolution.module] Create new issue IssueType.NO_CURRENT_BACKUP - ContextType.SYSTEM / None
23-05-20 08:52:03 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.MULTIPLE_DATA_DISKS/ContextType.SYSTEM
23-05-20 08:52:03 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_IPV6_ERROR/ContextType.DNS_SERVER
23-05-20 08:52:03 INFO (MainThread) [supervisor.host.services] Updating service information
23-05-20 08:52:03 INFO (MainThread) [supervisor.homeassistant.core] Wait until Home Assistant is ready
23-05-20 08:52:03 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_FAILED/ContextType.DNS_SERVER
23-05-20 08:52:04 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
23-05-20 08:52:04 INFO (MainThread) [supervisor.host.manager] Host information reload completed
23-05-20 08:52:05 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.SUPERVISOR
23-05-20 08:52:05 INFO (MainThread) [supervisor.resolution.check] System checks complete
23-05-20 08:52:05 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
23-05-20 08:52:05 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-05-20 08:52:05 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state CoreState.RUNNING
23-05-20 08:52:05 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
23-05-20 08:52:11 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
23-05-20 08:52:11 INFO (MainThread) [supervisor.backups.manager] Found 0 backup files
23-05-20 08:52:11 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-05-20 08:52:11 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/esphome/home-assistant-addon repository
23-05-20 08:52:11 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/hassio-addons/repository repository
23-05-20 08:52:11 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/home-assistant/addons repository
23-05-20 08:52:13 INFO (SyncWorker_2) [supervisor.docker.addon] Starting Docker add-on ghcr.io/hassio-addons/grafana/amd64 with version 7.6.0
23-05-20 08:52:13 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
23-05-20 08:52:13 INFO (MainThread) [supervisor.store] Loading add-ons from store: 71 all - 0 new - 0 remove
23-05-20 08:52:13 INFO (SyncWorker_0) [supervisor.docker.addon] Starting Docker add-on homeassistant/amd64-addon-google_assistant with version 2.5.0
23-05-20 08:52:19 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Google Assistant SDK is stopped, restarting...
23-05-20 08:52:19 INFO (SyncWorker_4) [supervisor.docker.interface] Cleaning addon_core_google_assistant application
23-05-20 08:52:20 INFO (MainThread) [supervisor.backups.manager] Found 0 backup files
23-05-20 08:52:23 INFO (SyncWorker_5) [supervisor.docker.addon] Starting Docker add-on homeassistant/amd64-addon-google_assistant with version 2.5.0
23-05-20 08:52:29 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Google Assistant SDK is stopped, restarting...
23-05-20 08:52:29 INFO (SyncWorker_2) [supervisor.docker.interface] Cleaning addon_core_google_assistant application
23-05-20 08:52:33 INFO (SyncWorker_1) [supervisor.docker.addon] Starting Docker add-on homeassistant/amd64-addon-google_assistant with version 2.5.0
23-05-20 08:52:33 INFO (MainThread) [supervisor.backups.manager] Found 0 backup files
23-05-20 08:52:38 INFO (MainThread) [supervisor.homeassistant.core] Detect a running Home Assistant instance
23-05-20 08:52:38 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Google Assistant SDK is stopped, restarting...
23-05-20 08:52:38 INFO (SyncWorker_3) [supervisor.docker.interface] Cleaning addon_core_google_assistant application
23-05-20 08:52:41 INFO (SyncWorker_0) [supervisor.docker.addon] Starting Docker add-on homeassistant/amd64-addon-google_assistant with version 2.5.0
23-05-20 08:52:48 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Google Assistant SDK is stopped, restarting...
23-05-20 08:52:48 INFO (SyncWorker_5) [supervisor.docker.interface] Cleaning addon_core_google_assistant application
23-05-20 08:52:52 INFO (SyncWorker_4) [supervisor.docker.addon] Starting Docker add-on homeassistant/amd64-addon-google_assistant with version 2.5.0
23-05-20 08:52:58 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Google Assistant SDK is stopped, restarting...
23-05-20 08:52:58 INFO (SyncWorker_0) [supervisor.docker.interface] Cleaning addon_core_google_assistant application
23-05-20 08:53:01 INFO (SyncWorker_2) [supervisor.docker.addon] Starting Docker add-on homeassistant/amd64-addon-google_assistant with version 2.5.0
23-05-20 08:53:06 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Google Assistant SDK is stopped, restarting...
23-05-20 08:53:06 INFO (SyncWorker_0) [supervisor.docker.interface] Cleaning addon_core_google_assistant application
23-05-20 08:53:10 INFO (SyncWorker_2) [supervisor.docker.addon] Starting Docker add-on homeassistant/amd64-addon-google_assistant with version 2.5.0
23-05-20 08:53:16 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Google Assistant SDK is stopped, restarting...
23-05-20 08:53:16 INFO (SyncWorker_4) [supervisor.docker.interface] Cleaning addon_core_google_assistant application
23-05-20 08:53:20 INFO (SyncWorker_3) [supervisor.docker.addon] Starting Docker add-on homeassistant/amd64-addon-google_assistant with version 2.5.0
23-05-20 08:53:26 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Google Assistant SDK is stopped, restarting...
23-05-20 08:53:26 INFO (SyncWorker_3) [supervisor.docker.interface] Cleaning addon_core_google_assistant application
23-05-20 08:53:29 INFO (SyncWorker_2) [supervisor.docker.addon] Starting Docker add-on homeassistant/amd64-addon-google_assistant with version 2.5.0
23-05-20 08:53:34 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Google Assistant SDK is stopped, restarting...
23-05-20 08:53:34 INFO (SyncWorker_0) [supervisor.docker.interface] Cleaning addon_core_google_assistant application
23-05-20 08:53:37 INFO (SyncWorker_1) [supervisor.docker.addon] Starting Docker add-on homeassistant/amd64-addon-google_assistant with version 2.5.0
23-05-20 08:53:43 ERROR (MainThread) [asyncio] Task exception was never retrieved
future: <Task finished name='Task-5558' coro=<Addon.watchdog_container() done, defined at /usr/src/supervisor/supervisor/addons/addon.py:989> exception=AddonsJobError('Rate limit exceeded, more then 10 calls in 0:30:00')>
  File "/usr/src/supervisor/supervisor/addons/addon.py", line 1003, in watchdog_container
    await self._restart_after_problem(self, event.state)
  File "/usr/src/supervisor/supervisor/jobs/decorator.py", line 144, in wrapper
    raise on_condition(
supervisor.exceptions.AddonsJobError: Rate limit exceeded, more then 10 calls in 0:30:00
23-05-20 08:58:27 ERROR (MainThread) [supervisor.host.logs] No systemd-journal-gatewayd Unix socket available
23-05-20 09:24:03 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
