I’m unable to upgrade from 0.103.6 to 0.104.1 on Hass.io. The error message I keep getting is:
20-01-17 04:34:07 INFO (MainThread) [hassio.api.security] /homeassistant/update access from core_ssh
20-01-17 04:34:07 INFO (MainThread) [hassio.homeassistant] Update Home Assistant to version 0.104.1
20-01-17 04:34:07 INFO (SyncWorker_3) [hassio.docker.interface] Update image homeassistant/qemux86-64-homeassistant:0.103.6 to homeassistant/qemux86-64-homeassistant:0.104.1
20-01-17 04:34:07 INFO (SyncWorker_3) [hassio.docker.interface] Pull image homeassistant/qemux86-64-homeassistant tag 0.104.1.
20-01-17 04:34:25 ERROR (SyncWorker_3) [hassio.docker.interface] Can't install homeassistant/qemux86-64-homeassistant:0.104.1 -> 404 Client Error: Not Found ("no such image: homeassistant/qemux86-64-homeassistant:0.104.1: No such image: homeassistant/qemux86-64-homeassistant:0.104.1").
20-01-17 04:34:25 WARNING (MainThread) [hassio.homeassistant] Update Home Assistant image fails
I’ve tried from the GUI and the CLI. Any thoughts?
