Cannot work out a simple temperature offset!
I’ve read countless threads and guides and I cannot work out what I need to do. All I want is to add a -6 degree c to the following sensor:
“sensor.soil_sensor_temperature”
What exactly am I suppose to add to my config for something that should be so simple :sweat_smile:
You can’t change that sensor, but you can create a template sensor that will report the value you want. Use the Helpers tab to create a Template sensor, and your template will be
{{ states('sensor.soil_sensor_temperature') - 6 }}
Now you can use this new helper sensor in whatever situation you want the offset temperature to be displayed or used in automations, etc.
Close. Sensor states are strings and need converting to numbers first:
{{ states('sensor.soil_sensor_temperature')|float(0) - 6 }}
That works! Thanks!!!
I make this error every time. It’s nice that the UI for creating new template sensors shows a live preview so you can catch this kind of mistake right away. This is also a good reason to play around in the Template tab of the Developer Tools when creating new template sensors or templates to use in automations.
