I’m trying to use an ESP8266 smart bulb to notify in a few ways with different color patterns, but then return to its original state after the pattern is complete. The attached code works as long as the previous state was on, somehow. But, if the previous state was off, then the effect continues.
esphome:
friendly_name: Livingroom Light
esp8266:
board: esp01_1m
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
password: "SuperSecretHere..."
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Livingroom Light Fallback"
password: !secret fallback_ap_pw
# PWM outputs for each LED channel
output:
- platform: esp8266_pwm
pin: GPIO4
frequency: 240 Hz
pin: GPIO12
frequency: 240 Hz
pin: GPIO14
frequency: 240 Hz
max_power: 14%
pin: GPIO5
frequency: 240 Hz
pin: GPIO13
frequency: 240 Hz
light:
- platform: rgbww
red: pwm_red
green: pwm_green
blue: pwm_blue
cold_white: pwm_cw
warm_white: pwm_ww
cold_white_color_temperature: 6500 K
warm_white_color_temperature: 2700 K
# constant_brightness: true
# color_interlock: true
effects:
- strobe:
colors:
- brightness: 100%
duration: 500ms
color_mode: white
- state: False
duration: 500ms
- strobe:
colors:
- color_mode: RGB
brightness: 100%
red: 0.0
green: 1.0
blue: 0.0
duration: 1000ms
- state: False
duration: 1000ms
- strobe:
colors:
- color_mode: RGB
brightness: 100%
red: 0.0
green: 1.0
blue: 0.0
duration: 50ms
- color_mode: RGB
brightness: 100%
red: 1.0
green: 0.0
blue: 0.0
duration: 50ms
- strobe:
colors:
- color_mode: RGB
brightness: 100%
red: 1.0
green: 0.0
blue: 0.0
duration: 800ms
- color_mode: RGB
brightness: 100%
red: 0.0
green: 1.0
blue: 0.0
duration: 2000ms
globals:
- id: light_color_set
type: LightColorValues
# Note: Restoration fails if previous state was off...
button:
on_press:
then:
- globals.set:
value: !lambda 'return id(main_light).current_values;'
- light.turn_on:
effect: Laundry
- delay: 6s
- lambda: |-
auto call = id(main_light).turn_on();
auto colormode = id(light_color_set);
call.set_color_mode(colormode.get_color_mode());
call.set_state(colormode.get_state());
call.set_brightness(colormode.get_brightness());
call.set_color_brightness(colormode.get_color_brightness());
call.set_red(colormode.get_red());
call.set_green(colormode.get_green());
call.set_blue(colormode.get_blue());
call.set_warm_white(colormode.get_warm_white());
call.set_cold_white(colormode.get_cold_white());
call.set_effect(0u);
call.perform();
on_press:
then:
- globals.set:
- light.turn_on:
effect: SevenOclock
- delay: 7s
- lambda: |-
call.perform();
on_press:
then:
- globals.set:
- light.turn_on:
effect: PhoneRing
- delay: 1500ms
- lambda: |-
call.perform();
on_press:
then:
- globals.set:
- light.turn_on:
effect: Doorbell
- delay: 1800ms
- lambda: |-
call.perform();
time:
- platform: homeassistant
timezone: US/Central
captive_portal:
