Can't add devices to Deconz
Hi. I just reinstalled Hassio on a SSD instead of my old SD-card and now I can’t add devices to Deconz anymore.
Here is the log:
[12:40:57] INFO: Starting Nginx…
[12:40:57] INFO: Running Home Assistant discovery task…
[12:40:57] INFO: Running the deCONZ OTA updater…
2020/04/14 12:40:57 [notice] 468#468: using the “epoll” event method
2020/04/14 12:40:57 [notice] 468#468: nginx/1.10.3
2020/04/14 12:40:57 [notice] 468#468: OS: Linux 4.19.106-v8
2020/04/14 12:40:57 [notice] 468#468: getrlimit(RLIMIT_NOFILE): 1048576:1048576
2020/04/14 12:40:57 [notice] 468#468: start worker processes
2020/04/14 12:40:57 [notice] 468#468: start worker process 478
[12:40:57] INFO: Running the IKEA OTA updater…
[12:40:57] INFO: Running the LEDVANCE/OSRAM OTA updater…
[12:40:57] INFO: deCONZ is set up and running!
12:41:07:389 found node plugin: libstd_otau_plugin.so - STD OTAU Plugin
12:41:07:437 dev /dev/ttyAMA0
12:41:07:437 COM: --dev: /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2137784-if00 (RaspBee)
This plugin does not support propagateSizeHints()
[12:41:08] INFO: Successfully send discovery information to Home Assistant.
12:41:08:320 Announced to internet http://dresden-light.appspot.com/discover
12:41:17:177 dev /dev/ttyAMA0
12:41:17:178 COM: --dev: /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2137784-if00 (RaspBee)
12:41:17:224 Device firmware version 0x264A0700
12:41:17:239 unlocked max nodes: 200
12:41:17:362 Device protocol version: 0x010B
12:41:17:375 new node - ext: 0x00212effff05184a, nwk: 0x0000
12:41:17:462 Current channel 11
12:41:17:483 CTRL ANT_CTRL 0x03
12:41:17:517 Device protocol version: 0x010B
12:41:17:578 Current channel 11
12:41:17:599 CTRL ANT_CTRL 0x03
12:41:27:141 channel 11 does not match channel mask 0x00008000 (TODO)
12:41:27:141 channel is 11 but should be 15, start channel change
12:41:27:141 Skip automatic channel change, TODO warn user
Not sure what the problem is, but I’d be tempted to start by switching the zigbee controller to channel 15 in phoscon
I’ve tried that but I can’t change the channel. Just getting errors.
Did go back to my SD-card and now all works great again.
The Conbee II does not like the SSD it seams.
Thats a known issue, there are interference between USB3 devices such as external disks and Conbee. I think the recommended solution is to put it on an usb hub
Hello, I fixed that issue after reading that Conbee II stick USB is having interference with SSD.
When I take away the SDD from the Conbee II Stick with an extension cable, it did recognize the sensors.
Try taking away both devices from each other and try again.
Hey Deun,
I think I having the same issue as you, but I have to understand what you are saying.
So you had both the SSD and ConBeeII stick on the same USB extension cable?
Because i do not use any USB extension cable and my SSD is running from USB3 and the ConBee on USB2. So I need to know what you did.
