@lolouk44 can this possibly explain why I can’t get my nest working again after a move to HASS.IO?
It’s been working perfectly for a long time now and after reinstalling and migrating to hassio, I can’t get the nest component to add me. After entering the pin I get: Internal error validating code
The logs state:
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 600, in urlopen
chunked=chunked)
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 343, in _make_request
self._validate_conn(conn)
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 839, in _validate_conn
conn.connect()
File "/usr/local/lib/python3.7/site-packages/urllib3/connection.py", line 301, in connect
conn = self._new_conn()
File "/usr/local/lib/python3.7/site-packages/urllib3/connection.py", line 168, in _new_conn
self, "Failed to establish a new connection: %s" % e)
urllib3.exceptions.NewConnectionError: <urllib3.connection.VerifiedHTTPSConnection object at 0x6e975910>: Failed to establish a new connection: [Errno -2] Name does not resolve
File "/usr/local/lib/python3.7/site-packages/requests/adapters.py", line 449, in send
timeout=timeout
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 638, in urlopen
_stacktrace=sys.exc_info()[2])
File "/usr/local/lib/python3.7/site-packages/urllib3/util/retry.py", line 398, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='api.home.nest.com', port=443): Max retries exceeded with url: /oauth2/access_token (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x6e975910>: Failed to establish a new connection: [Errno -2] Name does not resolve'))
File "/usr/local/lib/python3.7/site-packages/homeassistant/components/nest/config_flow.py", line 105, in async_step_link
tokens = await flow['convert_code'](user_input['code'])
File "/usr/local/lib/python3.7/site-packages/homeassistant/components/nest/local_auth.py", line 39, in resolve_auth_code
await hass.async_add_job(auth.login)
File "/usr/local/lib/python3.7/site-packages/nest/nest.py", line 175, in login
response = post(ACCESS_TOKEN_URL, data=data, headers=headers)
File "/usr/local/lib/python3.7/site-packages/requests/api.py", line 116, in post
return request('post', url, data=data, json=json, **kwargs)
File "/usr/local/lib/python3.7/site-packages/requests/api.py", line 60, in request
return session.request(method=method, url=url, **kwargs)
File "/usr/local/lib/python3.7/site-packages/requests/sessions.py", line 533, in request
resp = self.send(prep, **send_kwargs)
File "/usr/local/lib/python3.7/site-packages/requests/sessions.py", line 646, in send
r = adapter.send(request, **kwargs)
File "/usr/local/lib/python3.7/site-packages/requests/adapters.py", line 516, in send
raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='api.home.nest.com', port=443): Max retries exceeded with url: /oauth2/access_token (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x6e975910>: Failed to establish a new connection: [Errno -2] Name does not resolve'))
Name does resolve when I try it manually, I’ve even tried entering all the ip addresses for the api.home.nest.com
Is this related?
