Cant add nodes anymore (ADD_NODE_STATUS_FAILED)
Hi All,
Months ago I add without any problem many Zwave nodes to HA.
Now when I want add one I see this error. Its not possible to add a node anymore.
Only change between then and now > changed from RPi3 to RPi4
AEON Labs ZW090 Z-Stick Gen5 EU is attached using a USB hub (RPI4 issue USB2/3 thing) This hub is not a powered one.
What can this be?
Oh have 3 modules I only use with Chrismas, so they are stored now. Have 3 failed nodes. But this cannot give this problem?
2020-02-25 08:39:11.952 Detail, Queuing (Controller) Add Device
2020-02-25 08:39:11.952 Info, Add Device
2020-02-25 08:39:11.952 Detail, contrlr, Queuing (Command) ControllerCommand_AddDevice: 0x01, 0x05, 0x00, 0x4a, 0xc1, 0x65, 0x14
2020-02-25 08:39:11.952 Detail, Notification: ControllerCommand - Starting
2020-02-25 08:39:11.954 Detail,
2020-02-25 08:39:11.954 Info, contrlr, Sending (Command) message (Callback ID=0x65, Expected Reply=0x4a) - ControllerCommand_AddDevice: 0x01, 0x05, 0x00, 0x4a, 0xc1, 0x65, 0x14
2020-02-25 08:39:12.005 Detail, contrlr,   Received: 0x01, 0x07, 0x00, 0x4a, 0x65, 0x07, 0x00, 0x00, 0xd0
2020-02-25 08:39:12.006 Detail,
2020-02-25 08:39:12.006 Info, contrlr, FUNC_ID_ZW_ADD_NODE_TO_NETWORK:
2020-02-25 08:39:12.006 Info, contrlr, ADD_NODE_STATUS_FAILED
2020-02-25 08:39:12.006 Detail, contrlr, Removing current message
2020-02-25 08:39:12.006 Detail, contrlr, Queuing (Command) Add Node Stop: 0x01, 0x04, 0x00, 0x4a, 0x05, 0xb4
2020-02-25 08:39:12.006 Detail, Notification: ControllerCommand - Failed
2020-02-25 08:39:12.007 Detail,
2020-02-25 08:39:12.007 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x4a) - Add Node Stop: 0x01, 0x04, 0x00, 0x4a, 0x05, 0xb4
2020-02-25 08:39:12.058 Detail, contrlr,   Received: 0x01, 0x07, 0x00, 0x4a, 0x65, 0x06, 0x00, 0x00, 0xd1
2020-02-25 08:39:12.059 Detail,
2020-02-25 08:39:12.059 Info, contrlr, FUNC_ID_ZW_ADD_NODE_TO_NETWORK:
2020-02-25 08:39:12.059 Detail, Node006,   Expected reply was received
2020-02-25 08:39:12.059 Detail, Node006,   Message transaction complete
2020-02-25 08:39:12.059 Detail, contrlr, Removing current message
2020-02-25 08:39:12.059 Detail, Notification: ControllerCommand - Completed
Did you ever figure out what the issue is? I’m seeing the exact same thing…
No not at all, i replaced the “AEON Labs ZW090 Z-Stick Gen5 EU” with a “Silicon Labs ACC-UZB3-E-STA”
https://www.digikey.com/product-detail/en/silicon-labs/ACC-UZB3-E-STA/703-1127-ND/6111631
Also moved to Zwave2MQTT Add-ON. Now all my problems are gone!!!
Even i can plug the Zwave stick directly into my RPI4 again without hub!!
Im a very happy Zwaver now :smiley:
any luck? i’m now having this issue…
I think mine ended up being a failing device (the device I was trying to add) after many attempts (and putting the controller directly beside the device) I was able to get it to add…and then it seemed to work mostly ok for maybe a couple weeks, then one day it was just dead…totally non-responsive. I replaced it and now all is well
