it whont start
Add-on: OpenThread Border Router
OpenThread Border Router add-on
Add-on version: 2.15.2
You are running the latest version of this add-on.
System: Home Assistant OS 17.1 (aarch64 / raspberrypi4-64)
Home Assistant Core: 2026.3.2
Home Assistant Supervisor: 2026.03.2
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
s6-rc: info: service banner successfully started
s6-rc: info: service otbr-agent: starting
[20:03:12] INFO: Setup OTBR firewall...
[20:03:13] INFO: Migrating OTBR settings if needed...
2026-03-20 20:03:13 homeassistant asyncio[226] DEBUG Using selector: EpollSelector
2026-03-20 20:03:13 homeassistant zigpy.serial[226] DEBUG Opening a serial connection to '/dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2439268-if00' (baudrate=115200, xonxoff=False, rtscts=False)
2026-03-20 20:03:13 homeassistant zigpy.serial[226] DEBUG Connection made: SerialTransport(<_UnixSelectorEventLoop running=True closed=False debug=False>, <universal_silabs_flasher.spinel.SpinelProtocol object at 0x7fb75a23d0>, Serial<id=0x7fb75b0b50, open=True>(port='/dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2439268-if00', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=0, xonxoff=False, rtscts=False, dsrdtr=False))
2026-03-20 20:03:13 homeassistant universal_silabs_flasher.spinel[226] DEBUG Sending frame SpinelFrame(header=SpinelHeader(transaction_id=3, network_link_id=0, flag=2), command_id=<CommandID.PROP_VALUE_GET: 2>, data=b'\x08')
2026-03-20 20:03:13 homeassistant universal_silabs_flasher.spinel[226] DEBUG Sending data b'~\x83\x02\x08\xbc\x9a~'
2026-03-20 20:03:14 homeassistant universal_silabs_flasher.spinel[226] DEBUG Failed to send SpinelFrame(header=SpinelHeader(network_link_id=0, flag=2), command_id=<CommandID.PROP_VALUE_GET: 2>, data=b'\x08'), trying again in 0.10s (attempt 1 of 4)
2026-03-20 20:03:14 homeassistant universal_silabs_flasher.spinel[226] DEBUG Sending frame SpinelFrame(header=SpinelHeader(transaction_id=3, network_link_id=0, flag=2), command_id=<CommandID.PROP_VALUE_GET: 2>, data=b'\x08')
2026-03-20 20:03:14 homeassistant universal_silabs_flasher.spinel[226] DEBUG Sending data b'~\x83\x02\x08\xbc\x9a~'
2026-03-20 20:03:15 homeassistant universal_silabs_flasher.spinel[226] DEBUG Failed to send SpinelFrame(header=SpinelHeader(network_link_id=0, flag=2), command_id=<CommandID.PROP_VALUE_GET: 2>, data=b'\x08'), trying again in 0.10s (attempt 2 of 4)
2026-03-20 20:03:15 homeassistant universal_silabs_flasher.spinel[226] DEBUG Sending frame SpinelFrame(header=SpinelHeader(transaction_id=3, network_link_id=0, flag=2), command_id=<CommandID.PROP_VALUE_GET: 2>, data=b'\x08')
2026-03-20 20:03:15 homeassistant universal_silabs_flasher.spinel[226] DEBUG Sending data b'~\x83\x02\x08\xbc\x9a~'
2026-03-20 20:03:16 homeassistant universal_silabs_flasher.spinel[226] DEBUG Failed to send SpinelFrame(header=SpinelHeader(network_link_id=0, flag=2), command_id=<CommandID.PROP_VALUE_GET: 2>, data=b'\x08'), trying again in 0.10s (attempt 3 of 4)
2026-03-20 20:03:17 homeassistant universal_silabs_flasher.spinel[226] DEBUG Sending frame SpinelFrame(header=SpinelHeader(transaction_id=3, network_link_id=0, flag=2), command_id=<CommandID.PROP_VALUE_GET: 2>, data=b'\x08')
2026-03-20 20:03:17 homeassistant universal_silabs_flasher.spinel[226] DEBUG Sending data b'~\x83\x02\x08\xbc\x9a~'
2026-03-20 20:03:18 homeassistant universal_silabs_flasher.spinel[226] DEBUG Failed to send SpinelFrame(header=SpinelHeader(network_link_id=0, flag=2), command_id=<CommandID.PROP_VALUE_GET: 2>, data=b'\x08'), trying again in 0.10s (attempt 4 of 4)
2026-03-20 20:03:18 homeassistant zigpy.serial[226] DEBUG Waiting for serial port to close
2026-03-20 20:03:18 homeassistant zigpy.serial[226] DEBUG Connection lost: None
File "/usr/local/lib/python3.11/dist-packages/universal_silabs_flasher/spinel.py", line 213, in send_frame
return await asyncio.shield(future)
asyncio.exceptions.CancelledError
File "/usr/local/bin/migrate_otbr_settings.py", line 189, in <module>
asyncio.run(main())
File "/usr/lib/python3.11/asyncio/runners.py", line 190, in run
return runner.run(main)
File "/usr/lib/python3.11/asyncio/runners.py", line 118, in run
return self._loop.run_until_complete(task)
File "/usr/lib/python3.11/asyncio/base_events.py", line 653, in run_until_complete
return future.result()
File "/usr/local/bin/migrate_otbr_settings.py", line 126, in main
hwaddr = await get_adapter_hardware_addr(args.adapter, args.baudrate)
File "/usr/local/bin/migrate_otbr_settings.py", line 84, in get_adapter_hardware_addr
rsp = await protocol.send_command(
File "/usr/local/lib/python3.11/dist-packages/universal_silabs_flasher/spinel.py", line 245, in send_command
return await self.send_frame(frame, **kwargs)
File "/usr/local/lib/python3.11/dist-packages/universal_silabs_flasher/spinel.py", line 212, in send_frame
async with asyncio_timeout(timeout):
File "/usr/lib/python3.11/asyncio/timeouts.py", line 98, in __aexit__
raise TimeoutError
TimeoutError
[20:03:18] WARNING: otbr-agent exited with code 1 (by signal 0).
Chain OTBR_FORWARD_INGRESS (0 references)
target prot opt source destination
DROP all -- anywhere anywhere PKTTYPE = unicast
DROP all -- anywhere anywhere match-set otbr-ingress-deny-src src
ACCEPT all -- anywhere anywhere match-set otbr-ingress-allow-dst dst
otbr-ingress-deny-src-swap
otbr-ingress-allow-dst-swap
Chain OTBR_FORWARD_EGRESS (0 references)
[20:03:18] INFO: OTBR firewall teardown completed.
s6-svlisten1: fatal: /run/s6-rc/servicedirs/otbr-agent failed permanently or its supervisor died
s6-rc: warning: unable to start service otbr-agent: command exited 1
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service banner: stopping
s6-rc: info: service mdns: stopping
/run/s6/basedir/scripts/rc.init: warning: s6-rc failed to properly bring all the services up! Check your logs (in /run/uncaught-logs/current if you have in-container logging) for more information.
/run/s6/basedir/scripts/rc.init: fatal: stopping the container.
s6-rc: info: service banner successfully stopped
Default: mDNSResponder (Engineering Build) (Nov 24 2025 09:07:59) stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
[20:03:18] INFO: mDNS ended with exit code 4 (signal 0)...
s6-rc: info: service mdns successfully stopped
