And for what its worth, reconnecting the Sonoff dongle directly to the Raspberry pi 5 caused issues again. I needed to keep it connected to the unpowered usb hub. (I suspect powered / unpowered / extension doesn’t really matter, it just needs to be physically away from the raspberry pi 5 by some amount)
Regarding this issue, I submitted an issue to ZHA.
Same issues here but I got it working after I disabled Bluetooth on my RPI!
same issue here!, no way to get it working, it failed since 2-3 weeks ago
Same issue, but different Hardware. I’m using a Mac Mini running VMWare ESXi and have been using an extension cable.
Currently using the Conbee2 for day to day Zigbee and forgot I’d left the Sonoff left plugged in after a previous migration plan stalled. I was prompted to look into it after recently seeing a detection of the device after a reboot.
Given that my system/network is currently working fine is there any benefit in pursuing this?
I was having the exact same problem after migrating my Zigbee network to the Sonoff 3.0 Plus (Skyconnect is using the extension cable it came with and the Sonoff was directly plugged into the Pi but it’s a 3B+ so it couldn’t have been intereference from USB 3.0).
Each time I rebooted it would come up with the “Add Sonoff Integration”, even after a (somewhat?) successful migration. Clicking Add I would get “Failed to probe the USB device”. I tried using the Skyconect’s extension cable, exact same thing. Thankfully I had an ancient unpowered USB hub laying around so I figured “what do I have to lose”? It actually asked me if I wanted to migrate this time (there was nothing anymore left to migrate) but I proceeded. Automatic migration failed (as it did the first time around), but doing an Advanced migration (of what? the Sonoff was already in charge of the Zigbee network and I’ve long since flashed Thread onto the Skyconnect, it was just the “Add Sonoff integration” that kept popping up every time even though it was working fine).
Long story short, it apparently successfully migrated itself using the unpowered usb hub and the message seems to have stopped appearing now (even after removing it from the usb hub and plugging it back in directly, no msg anymore even after a reboot).
I don’t have an actual “Sonoff” integration like I do for the Skyconnect (or ZHA-1), but it is (still) listed. Is this normal?
This is what it looks like.
I’ve been told my 3B+ is underpowered and that HA needs at least 2 gigs of ram to run properly (and I’m getting a ton of hci0: bluetooth errors - hopefully the 5 fixes this).
But yeah, I want to make sure everything is (now) fine with my HA installation and I can just use an upgrade. I keep getting the feeling something went wonky during the migration process (it didn’t rename the Skyconnect to Snoff for one, but that I can live with if everything else is as it should be).
Any input from the Sonoff owners? Do you have an actual Sonoff integration or is it just listed as a device under zha?
Hi everyone, I’m having the same issue and I’m fairly new to this.
Could those with more experience please advise on the most likely cause of the problem and the best solution?
I’ve read through the existing discussion and the accepted answer, but I’m still struggling to understand what actually solves the issue. In particular, the mention of an “official power supply” isn’t clearly explained, and I’m unsure how it applies to my setup.
Here is my exact configuration and what I’ve tried so far:
- Device: Zigbee USB Dongle, version E
Reference: https://www.amazon.fr/dp/B0B6P22YJC - Test 1: Connected directly to my mini-PC via USB
→ The dongle is detected, but it fails with the error:
“Failed to probe the USB device.” - Test 2: Connected via a NOVOO USB hub (unpowered)
Reference: https://www.amazon.fr/NOVOO-Aluminium-ChromeBook-Matebook-Tablette/dp/B075FGQ988
→ Same result: the device is detected, but it fails with
Also, I am using HA (homeassistant/home-assistant:2025.12) via docker.
The accepted answer mentions success after using a longer USB extension, an unpowered hub, and the “official power supply,” but it’s not clear which component actually made the difference or why (is it because it was unpowered ? because long ?..) .
At this point, buying additional equipment just to see if it works isn’t really an option for me. Is there a more systematic way to debug this (power issues, USB interference, logs to check, etc.) rather than relying on trial and error?
Any clarification or guidance would be greatly appreciated.
I have the same issue
- standaard PC
- SONOFF Dongle Plus MG24 (latest firmware Zigbee 8.0.2)
- HA 2025.10.4 (Ubuntu snap)
Sorry, my problem was not a but bug. The snap installation had no rights to access the raw-usb.
martin@server1:~$ snap connections home-assistant-snap
Interface Plug Slot Notes
bluez home-assistant-snap:bluez - -
content - home-assistant-snap:components -
content - home-assistant-snap:configurations -
content - home-assistant-snap:vscs-content -
content home-assistant-snap:bin - -
desktop home-assistant-snap:desktop :desktop -
hardware-observe home-assistant-snap:hardware-observe :hardware-observe -
network home-assistant-snap:network :network -
network-bind home-assistant-snap:network-bind :network-bind -
network-control home-assistant-snap:network-control :network-control -
physical-memory-control home-assistant-snap:physical-memory-control - -
raw-usb home-assistant-snap:raw-usb :raw-usb manual
removable-media home-assistant-snap:removable-media - -
serial-port home-assistant-snap:serial-port - -
thanks to:
I had the issue and ii it drove me mad !
I’m not going to go on and ramble so here are the 4 things that it could be:
1, Sonoff Integration is installed as well as the Zigbee app - the Sonoff cant be just disabled, it needs to be uninstalled completely,
2, Take the Zigbee Dongle out of the case and do a full master reset - don’t believe anyone that says you can do it with taking the case off, - Then reflash
- Get a long USB cable and put some distance between the dongle and Host - it honestly makes a difference
4
4 Use a powered USB hub and plug it in that (with the hub plugged into the host) If you decide to go for option 4 - skip 3.
I guarantee it will work, unless you’ve messed up up your config somewhere the problem.
Hi, my SonOff USB decided to annoy me as well by throwing this “Failed to probe USB” error. I’m running HomeAssistant in a docker using ZHA for Zigbee (and the ZBT-1 USB device for matter/thread).
What do you mean by “Sonoff Integration is installed as well as the Zigbee app”
Also “ake the Zigbee Dongle out of the case and do a full master reset” is a bit unclear.
I don’t think the cable length is an issue; the HW setup has not been changed and has been working over a year
Solved - Turns out that the SonOff firmware somehow got corrupted. Using the online flashing tool to flash new firmware was enough to get the thing up-and-running again.
When "Zigbee2MQTT" and "SONOFF Dongle Flasher" are installed in the apps on HA, you can't add dongle as a device. It conflicts.
When you stop Zigbee2MQTT, you can add the dongle but in this scenario, you can't use Zigbee2MQTT... Maybe this can be the issue.
To start Zigbee2MQTT, you can stop SONOFF Dongle Flasher. Then you can start Zigbee2MQTT.
