File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 130, in handle_call_service
connection.context(msg),
File "/usr/src/homeassistant/homeassistant/core.py", line 1235, in async_call
await asyncio.shield(self._execute_service(handler, service_call))
File "/usr/src/homeassistant/homeassistant/core.py", line 1262, in _execute_service
await self._hass.async_add_executor_job(handler.func, service_call)
File "/usr/src/homeassistant/homeassistant/components/zwave/lock.py", line 175, in set_usercode
lock_node = network.nodes[node_id]
KeyError: 3
The “KeyError” is the return value thrown, and seems to always be the node_id i input (I have 3 locks, all the same brand)
Why can I not get/set user codes?
calling the lock.lock/unlock service works with no problem, and my other automations, which work on detecting a lock/unlock event also work well. So the devices are working, but the usercodes set/get/clear always return this error.
INFO:
System: Ubuntu 18.04.3 LTS
Home Assistant V: 0.98.4
Any help or debugging suggestions welcome. Ive been trying to resolve this for 7h straight
Have you solved this? I have pretty much the same issue - but I cannot even call lock/unlock services. I receive ‘failed to call service’ no matter what I try and test out on my BE469 locks (I have 2 identical).
I’m new to HA, and just recently got it all setup with my ZWave Aeon Labs Aeotec USB stick Gen5. I see the Zwave configured and I see devices listed on my overview panel or under devices. Just stuck now how I start calling services with ZWave.
Been able to do so with my Roku TV (turn on/off) - but that’s the only thing that has worked. Am still reading through the forums and just signed up to ask this question to you as I came across your post.
Yeah I figured ZWave should operate just like calling any other service - but it’s giving me some trouble so far. Will try what you have suggested and google some more information to see if I can figure it out. If I can’t - I may reach out to you again if you don’t mind, or start a new thread on the community forum.
